It is currently Tue May 20, 2025 3:22 am
PostPosted: Sun Nov 18, 2012 12:53 am
Well I had my pilot out for about 2-3hrs today and I I brought it into my garage to change out tires and once I got the tires changed out I was going to run it again but it wouldn't start..so I started going through EVERYTHING!! (When I turn the key on in the pilot the dash turns on and the lights work but when I hit the starter button nothing happens, so I just a crossed the seliniod and I got it to crank but it has not spark)...i tested my c.d.i, iginition coil, the thing to the right of the iginition coil (sorry I have no idea wht it's called) all those things tested out well
WHAT I HAVE SOO FAR BESIDES TESTING THAT STUFF I NOTED ABOVE...
I also took the dash off and sprayed electrod cleaner on the kill switch and the starter button and in all the connections on the steering column...someone please help me out
PostPosted: Sun Nov 18, 2012 1:28 am
Did you check the neutral safety switch on the tranny? If your standing behind the pilot on the left side of the tranny are 2 wires with rubber boots one bolts on and one is a push on connector the push on one comes loose all the time, turn your key on and wiggle the wires and see if the lights on the dash come on and off.
viewtopic.php?f=1&t=10909
PostPosted: Sun Nov 18, 2012 1:30 am
Also make sure it's in neutral and the green light is on on the dash.
PostPosted: Sun Nov 18, 2012 2:19 am
Afastcar, my pilot dash has the green light on I just checked and still nothing.
PostPosted: Sun Nov 18, 2012 3:30 am
Will it start if you pull start it?
PostPosted: Sun Nov 18, 2012 3:31 am
Check your fuses also.
PostPosted: Sun Nov 18, 2012 8:29 am
Their is a connection under the tool box by the steering column check it.
PostPosted: Sun Nov 18, 2012 9:58 am
Checked all the connections, already tried Pull start, already checked fuses
PostPosted: Sun Nov 18, 2012 2:16 pm
wiggle your shifter in and out of gear. I know your light is on but might work
PostPosted: Sun Nov 18, 2012 3:20 pm
Did you try a brand new plug?
PostPosted: Sun Nov 18, 2012 6:43 pm
I got it fixed..it ended up being some build up on the contacts on the kill switch
PostPosted: Mon Nov 19, 2012 3:22 am
Wow that is crazy. With all your lights on your switch only killed power to the starter and ignition. Ill make sure to add this to my check list when trouble shooting problems in the future. Thanks for finding this out :-)
