It is currently Mon May 19, 2025 4:36 pm
 Post subject: Leak Tester
PostPosted: Sun Nov 18, 2012 7:29 pm
Was looking for a thread on how to make a leak tester for another PO member, but couldnt find it. Can someone help out? Thanks.
 Post subject: Re: Leak Tester
PostPosted: Sun Nov 18, 2012 7:37 pm
This one?
[url]viewtopic.php?f=1&t=10811&hilit=leak+down[/url]
viewtopic.php?f=1&t=10811&hilit=leak+down" ."..
PostPosted: Sun Nov 18, 2012 7:46 pm
yeah, that one works. never seen that one before. one i have i use my air compressor, block off the pulse line and exhaust, and pressurize from the intake manifold
PostPosted: Sun Nov 18, 2012 8:41 pm
Nick, I use rubber freeze plugs from you local auto parts store and pressurize the crankcase through the pulse line for the fuel pump pulse line.
PostPosted: Sun Nov 18, 2012 9:12 pm
Rand,
Was that a pretty simple way to do it?
Thanks Nick for the info :-)
-Jason
PostPosted: Sun Nov 18, 2012 11:12 pm
I took the intake boot and the exhaust manifold to the auto parts store to get the sizes.
Pretty easy, the only thing you need to do is figure out a way to pressurize the Engine.
I used an air fitting that I hooked up to my compressor then a valve and pressure gauge to a nipple attached to the pulse hose.
PostPosted: Sun Nov 18, 2012 11:42 pm
Ok great, I do have a compressor, so I should be able to do it :-) I will dig up a gauge, etc.
-Jason
PostPosted: Mon Nov 19, 2012 3:20 am
Make sure you use a low amount of air when filling it up or you will pop your plugs off or blow a seal
PostPosted: Mon Nov 19, 2012 11:45 am
Thank Rusty, I forgot to mention not to over pressurize the Engine.
10 psi MAX!
PostPosted: Mon Nov 19, 2012 12:57 pm
**** Only fill your air compressor up to 10 psi***** so you don't have to worry about blowing any seals out....... toby
PostPosted: Mon Nov 19, 2012 3:46 pm
Yes, agreed, air compressor at 10psi to be safe. I have a dial that I can adjust my line pressure on my big compressor, so I dial it down. Too much pressure will mean blown gaskets.
PostPosted: Wed Nov 21, 2012 8:01 pm
I just picked up a 0-30 psi gage and a bulb-pump like that for like $12 total on eBay a week or so ago. My original leak tester with a small bicycle pump has worked great, but its gage is falling apart. Time for a new one. It looks exactly like the one above, except I have some nylon quick connects and nylon tubing.
PostPosted: Sun Nov 25, 2012 10:22 pm
Nick I have one you can use it.
PostPosted: Sun Nov 25, 2012 10:59 pm
Thanks Peter, I do have one, although it is a bit more "rednecky" lookin than yours! lol. Made mine out of a few spare parts I had laying around, but hey, it works!
You gonna ride new years with us in Glamis?
