It is currently Thu May 15, 2025 5:35 pm
 Post subject: Driven clutch
PostPosted: Tue Apr 16, 2013 1:29 pm
So I've got my rear driven apart and am trying to ID it
It looks to have a stock helix/cam and what I am guessing are the 90D shieves
The cam/helix is a two piece pressed assembly with six (6) bolts that are 6 X 1.00 metric thread, and it is different looking than any 90D pictures I can find on line
It was strange to me because I was trying to figure why Comet would have used metric threads on this part
The outer fixed shieve have a sticker on it that reads 301826C Nov 2000
This buggy was DOA when I got it, so I can't tell what it was like
Has anyone seen this kind of setup? Is it going to have issues
And yes, rust clean up is on tap
 Post subject: Re: Driven clutch
PostPosted: Tue Apr 16, 2013 6:03 pm
Yours is probably the same as mine I used on my 440 Pilot its a comet replacement for the FL350 driven or a 90D viewtopic.php?f=28&t=3007
More pics viewtopic.php?f=28&t=3024
Mine has the same sticker just the printing is worn off.
viewtopic.php?f=1&t=2052
Also used on the FL250 just a different shaft size viewtopic.php?f=1&t=9579
PostPosted: Tue Apr 16, 2013 9:05 pm
Yours is probably the same as mine I used on my 440 Pilot its a comet replacement for the FL350 driven or a 90D viewtopic.php?f=28&t=3007" ."..
More pics viewtopic.php?f=28&t=3024" ."..
viewtopic.php?f=1&t=2052" ."..
Also used on the FL250 just a different shaft size viewtopic.php?f=1&t=9579" ."..
Those are actually some of the photos I referenced
Your fixed helix/cam is different (you'd have to look at the back, or look at the casting inside to notice) yours most likely doesn't have bolts holding a metal back plate in, yours is probably solid alum
