It is currently Mon May 19, 2025 2:41 am
 Post subject: u joints
PostPosted: Mon Oct 06, 2014 11:41 pm
Does anyone out there have an up close photo of a broken u joint ??
I want to see what a failure looks like. At one time there was a lot of chatter on this site about this issue. I want to see what EXACTLY what breaks on the u joint.
 Post subject: Re: u joints
PostPosted: Wed Oct 08, 2014 1:54 pm
I have a bunch of spare axle parts that are on their way/out or whatever. What happens from what I can tell if the needle bearings get all crud and rust from lack of lubrication. From there the axle may still hold up well but eventually the U-Joint will start to wear down, and then cap as well. When it gets too sloppy the cap can start to crack or split. That's about all the info I have as I don't know what happens after that other than more slack and then major damage.
PostPosted: Wed Oct 08, 2014 2:54 pm
Thanks for the reply.
If you get one that grenades take a pic and post.
I still want to see the real thing.
PostPosted: Thu Oct 09, 2014 3:19 am
I had a busted up one but I cut it up for parts
Pretty much the cups break apart then it blows apart
I had a broken one and the center Yoke was still good I used it on my rotax odyssey when I rebuilt the axles anhit was still working great
PostPosted: Thu Oct 09, 2014 1:43 pm
Thanks for the info
