Yes you will need to take apart again and check your float system.
Make sure the floats are set to correct height,and are not leaking too.
Whenever I have finished servicing a carb,and BEFORE installing the bowl,I attach a clean line to the fuel inlet spigot and mouth blow while inverting the carb slightly to activate/see where the float shuts off.You will feel your blow get harder and harder,get chipmonk cheeks,then stop if all is working OK.Then I suck hard and if my tongue vacuum sticks to the tube,then all is OK too.
This way you can verify that the whole float system IS actually working properly BEFORE installing by simply simulating the fuel shutoff just by the line/mouth blow check method.
Warning petrol tastes horrible...plah,spit spit!
