It is currently Thu May 15, 2025 7:24 am
PostPosted: Fri Dec 05, 2014 6:16 pm
On our last ride of the season my brother crashed the oddzilla #2 hard.
The sad part is this machine was the nice one. All fenders in perfect shape and no rust on frame.
He did a triple flip (one in mid air) and took out the right front corner.
Smashed the front wheel into the frame. The damages were: Bent top J arm mount, bent J arm, bent bottom ball joint, all 4 fender damaged or destroyed, bent exhaust, one shock damaged and leaking. Here are some pictures of the repair. I can't believe how thin the wall is on the pipe. The frame I made with the comealong on it that you see in the pics did not work. I still had to cut the pipes and remove the Honda brace. Looks like I will add some triangle braces as well to help with strength. It is not completed yet, I got all winter.
PostPosted: Fri Dec 05, 2014 6:21 pm
A few more.
Even though the frame is made of thin wall mild steel tubing I am amazed at how strong it really is.
PostPosted: Fri Dec 05, 2014 6:37 pm
A triple flip? Man wheres the video!!
PostPosted: Fri Dec 05, 2014 8:50 pm
Yeah I know. I am mad to because it was on the roof when I came around the corner and he was just climbing out. Flipped it on its wheels before I could get a pic.
PostPosted: Sat Dec 06, 2014 6:31 am
I like the pulling rig
but in pic 20141205_131225.jpg it looks like the shaft is bent downwards
did you put the cuts in to help it straighten the shaft
PostPosted: Sat Dec 06, 2014 8:30 am
Of all the buggy forums I've been on...I've never seen anyone with more carnage posts/pics than you 2 bro' clowns. :-)
PostPosted: Sat Dec 06, 2014 11:26 pm
Lol. Yeah we drive m like we stole m.
PostPosted: Sat Dec 06, 2014 11:35 pm
Shaft is not bent downward. The picture just makes it look like that.
I did have to cut the top tube and the one coming down from the very top (the small hooked tube).
There was just no way I could pull it. By the way the pulling rig you see didn't work because when I heated the tube the only thing that started to bend was the tube that the rig was bolted to. I ended up hooking the come a long to my truck and the back end of oddy to hoist post.
