It is currently Wed May 14, 2025 11:34 am
 Post subject: Siezed bottom end woes
PostPosted: Sat Oct 14, 2017 10:19 pm
good evening
I have a project pilot here with a totally rusted and seized lower end, badly rusted might I add. My dilemma is it seized up where I cannot get the balancer out, meaning I cant split the cases due to this. I don't have torched here and have soaked for a week on PB BLASTER TO NO AVAIL.tHE CRANK is probably junk, so I don't care if I damage it as I have plenty here and 3 going to Speedchaser. Any ideas on how I can get the crank to turn jut enough so that balancer will be free.
PostPosted: Sat Oct 14, 2017 10:49 pm
good evening
Keep soaking it with PB Blaster and do not go Cave Man on it :-)
Any pictures of this new project?
PostPosted: Sun Oct 15, 2017 12:49 am
They make a chemical called "Evapo-Rust" that i have used on some stuck parts. It doesn't attack aluminum. I soaked a fl250 piston rod with a suck piston and pin on it to free up the bearing. I can't say it worked flawlessly, but it did free up the bearing so that it would spin. No damage to the aluminum at all.
PostPosted: Sun Oct 15, 2017 4:18 am
While letting blaster soak in tap it with a hammer every time u walk past it. This slight jolt helps to work the blaster into every nook and cranny.
PostPosted: Sun Oct 15, 2017 10:49 am
good evening
Hi hoser i wont go ape shit on it lol. I will need to send over for a rebuild when you have time btw if possible please
PostPosted: Sun Oct 15, 2017 10:52 am
Speedchaser recommended a product as well but warned of damage to the cases which i tested and imo thought it might damge them so thanks for the help will see if i can purchase locally.
The pb blaster frees the rod up on the crank however
Hoser will post pics in the section today
PostPosted: Sun Oct 15, 2017 7:08 pm
you can try to boil it in diesel fuel
out side :-)
brake fluid will penetrate just about any thing also :shock:
speed
PostPosted: Sat Oct 21, 2017 11:21 am
Try using this instead of the pb blaster. I've had good success using this on horribly rusted parts.
