It is currently Sun Nov 10, 2024 3:41 pm
 Post subject: High idle help!
PostPosted: Thu Jan 14, 2021 3:41 pm
I adjusted the idle out and it still idles high I bought a rebuild kit and replaced all the jets and it still idles high? Any advice?
 Post subject: Re: High idle help!
PostPosted: Thu Jan 14, 2021 4:58 pm
check for air leaks
PostPosted: Thu Jan 14, 2021 5:19 pm
Yep - Probably an air leak. Be careful you don't hurt the Engine. Don't run it anymore until you find and fix the leak.
I would check the cylinder base gasket - looking to see if it has blown out. Happen to my FL400.
If you do not see anything obvious, perform a leak down test. I would do a leak down test anyway.
Would love to see photos of your machine.
Registered users: Bing [Bot], eseymour72, Google [Bot], hoser, Lanix, MSN [Bot], MSNbot Media, W3C [Validator]
