It is currently Sat May 17, 2025 3:48 pm
 Post subject: Cylinder boring info/pix
PostPosted: Fri Jan 26, 2007 10:36 am
http://www.atvconnection.com/Department ... Boring.cfm
PostPosted: Fri Jan 26, 2007 11:44 am
Thanks for the link, lots not said their but its a good page to give you some idea whats done.
In his hone pics his hones look close to the same hones I use only problem is they all 3 look like he used them DRY, you can see the dust on them from honing, I have never heard of using a Engine hone dry on a cylinder hmmm I will have to ask around what the deal is, all I have read about finish hone says that if you don't use a quality oil and not enough oil it tears the metal it don't cut it, end results is metal in your Engine, the rings and piston scrape it off then it floats around in your Engine, shortens bore and Engine life including the rings.
