It is currently Sat May 17, 2025 6:44 pm
 Post subject: fl250 stud pattern????
PostPosted: Fri Jan 26, 2007 10:32 pm
hi
im ordering some rear rims to be made, but i don't know the stud pattern that the need to drill? i thought i read somewhere it was a 100mm on 3 stud pattern, but when i measured it it was only 85mm or so from the center of one hole to the next???? wtf
can anyone help?
thanks josh
File comment: the red arrow is where i measure on all 4 rims
PostPosted: Fri Jan 26, 2007 10:41 pm
Owners or service manual does not list the bolt pattern in the specs?
don't have a manual handy here or I would look...
PostPosted: Fri Jan 26, 2007 10:50 pm
the manual doesn't say anything about the stud pattern, all it says is to rplace broken rims with HONDA REPLACEMENTS, (which in australia are $380 each!). i suppose ill just wait until my dad gets back from shooting :shock:
thanks for the reply hoser :-)
josh
 Post subject: Rear Rims
PostPosted: Fri Jan 26, 2007 11:55 pm
I have the 84 FL250 with the 4 lug rear rims on 130mm.....but I did some checking and it does seem that the rear rims, 3 lug, are 100mm......dunno if this helps or not.....
PostPosted: Sat Jan 27, 2007 12:30 am
i thought it was 3 on 100, thanks ill write it down so i don't forget. did 84' s come out with a 4 stud hub, or is it off another quad?
and yes your info has helped
