It is currently Fri May 16, 2025 12:05 am
PostPosted: Fri Nov 28, 2008 10:49 pm
Ok, I got the no spark probem fixed. Got the Odyssey put all back together, but the belt is tight, and when I try to start it i(yank the pull start) it lurches forward. Finally I put a jack under the rear end and lifted the tires off of the ground and it started right up. However, the drive engages immediately. I haven't had a chance to look closely at the drive.... it started getting dark before I could get in to it.... but I am wondering.... I don't know how long it has been sitting, so is it possible the clutch could be stuck, and perhaps is there a way to adjust it out? The belt I put on it is brand new, and yes, it is the right one... I compared it to the old one (which was pretty worn). So I'm thinking there must be an adjustment. I've never had to do that before, so I could use some advice....
Thanks in advance.....
PostPosted: Sat Nov 29, 2008 1:37 am
If it is indeed the correct belt (the old one could have been a worn out TOO tight belt) then my guess would be the drive clutch is stuck closed.
Can you take and post some pics of the two clutches with the belt installed?
