Joined: Fri Jan 12, 2007 2:17 pm Posts: 3636 Location: Wichita ks
I get mine from Smiley's race shop. There located in Texas, Oklahamo and Kansas. The steel and Al tube are around 13 to 17 a piece depending on lenght. and the chromolly are avalible for around 26 to 30 a piece. I use the chromolly end with the self lubracating insert. The ends ( hiems) run around 13 to 17 a piece. I use the 5/8 with a 5/8 to 1/2 hiem with shim stock to mm. I will replace Toebys stock with them due they don not bind up at full droop and compression and alow for smoother articulation of the suspion to which the shock is more effecive. Depending on set up you will need two 13" and four 14" or two 14" and four 15" tubes for atv LT axles I am working another set up using 15/16 and 16/17 for the 14" travle kit. Tobeys will have close to stock set and try to get for 9" travle using stock axles and new upper. Any race shop should have them. If they work for a 3,000 lb race car they should handle a 600 pound car. Time will tell. The stell in great for fab work to reduce cost and final set up using the chromolly ones. The nice thing about these is the cost for replacemnet and having spare that universal. Any way as always TMI.
