It is currently Fri May 16, 2025 3:26 pm
PostPosted: Mon Jan 30, 2012 10:53 pm
My stock shocks needed a makeover. VERY simple project, remove spring (no special tools required), clean chrome, clean plastic inner tube, paint spring, reassemble, that's it! Check out the results.
File comment: Before
File comment: After
File comment: This is the Paint I used
PostPosted: Tue Jan 31, 2012 11:14 am
Heck yes -- don't just cover 'em up with $30 shock wears, clean 'em up!! =)
Same goes for the rear shocks on the FL350R...some elbow grease and paint makes this stuff look like new. =) Just un-thread the end off the shock and it's a breeze.
On the spring, I used some blue gloss rust-o-leum, about 3-4 coats after giving about 5-min of wire-wheeling. On the plastic cover, just some cleaner and some krylon black (for plastic). Then the shock body and ends get some light wire wheeling, #000 steel wool, and finished with some light clear coat that's "baked on" with a heat gun for ~30 seconds. Rubber stoppers get cleaned with armor-all. Lastly, use a small flat-head screwdriver or pick to clean the grime off the eyelet seals. VOILA!
Front shocks FL350R...you need a spring compressor to tear it down.
Check the finish on the shock shaft, too. You want it to be smooooth and shiney.
PostPosted: Tue Jan 31, 2012 1:59 pm
Very nice. In my opinion, shock covers contributed to the poor condition of my shocks. The covers were made out of neoprene which held a ton of moisture. That, combined with the exposed metal from the constant rubbing, caused the surface rust you see on the springs.
PostPosted: Wed Feb 01, 2012 12:37 pm
Sweet.
Nice improvement.
PostPosted: Wed Feb 15, 2012 4:20 pm
Looks really nice!....
PostPosted: Mon Feb 20, 2012 11:46 am
I'll post my shocks to you,and get spcled1 to paypal you the $6.99.......heck I'll just go the whole hog and paypal ya $7.00! Image
Registered users: Baidu [Spider], Bing [Bot], canadian oddy, Google [Bot], Lanix, liduno
