Dave-Co wrote:
so la sleeve can install that into the pilot cylinder? If so why are people getting the studs and case modafied? Seams the sleve would be much simpler gor a 500 conversion. Am I missing something?
Port layout is different on the CR500 cylinders they are using when they do the case modifications.
Let me tell you something about that CR500 mod over the years I have rode with 4 different Pilots that had the ATV Racing CR500 mod and drag raced them all and during the whole drag race was right along side them every step of the way, we raced on hard pack and soft sand even up tall sand hills same results, two of these conversions were also running race gas had the high compression.
A full mod 400 will run with the CR500 mods why bother, heck I was having traction problems with my Pilot not really sure how I could hook up any more power, when I swapped to my 440 sled
Engine that's why I detuned it by going to a 2 into 2 pipe and with just a single 38mm carb rather than twin AAEN modified pipes and 44mm twin carbs.
Why are you considering a bigger bore than the 400, whats your goal?
EDIT (added more)If I was going to go to a CR500 cylinder it would be one of Calvin Pollets 500 cylinders you can get it up to 583cc
http://www.cpindinc.com/pub/view_product/63?lm=5&name=3101-9779-144If you go with the CR500 you will need the pipe too the 400 pipe is different I would get the pipe specs from Calvin and have one of your local pipe builders build you a pipe to his specs, my first choice would be Bills pipes they seem to have high quality products.
No clue how good that CR500 pipe is from ATV Racing could be a copy of the stock pipe for all I know, if you get the pipe specs from Calvin you could reverse engineer the ATVR pipe (measure it) see how well it matched the CPI design.
CPI was suppose to make a adapter to bolt right on the Pilot bottom end dunno if it ever happen see this post.
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=8999&start=0
