ZeroClient wrote:
OK I guess I was confused between MM and ". 80thou would be 2mm. I was thinking .080 was .8mm and so I thought 2.03mm was too much, when its not. 2.03mm deck clearance is going to make a very loose squish (Probably 80 thousandths or more).
If you were making a high octane/performance
Engine then I would still tell you to get the squish down to about 40 thousandths. You can accomplish this two ways:
1. Deck the base of the cylinder. Fr this you'd need to carefully heat and press out the sleeve, deck, then re-install the sleeve. In fact if you did do this; I'd actually recommend replacing the sleeve for an 80mm one.
2. Deck the top of the cylinder. Much easier done.
#1 - Deck the base has the added benefit of changing port timings. This would give you an opportunity to make lots more adjustments given some porting knowledge. #1 would be much harder for the layman Engine builder.
I just looked in my notes and previously noted my Pilot Engine has a .28mm (11 thou) deck gap. You being at 2.03... that's a number designed for air-cooled engines... Think about it.
Bottom line - I suggest you deck the cylinder top. By how much I cannot tell you exactly because ultimately it would need to be relevant with the squish band you'll be cutting into your head - which should be at about a 10 degree angle.
Thank you
No I can't build a performance Engine.
I just don't have the tooling or the technical abilities.
Decking and sleeving is way out of my skill/tooling range as I have not done either one of those.
This is just gona be a basic Engine with a welded up piston. Right at the moment I am leaning towards running that homemade head with a stock gasket which will really open up the squish but it will drop my compression to a reasonable level. Hell I might even start over and make another head with a deeper combustion chamber. Not sure yet.
Well off to the little city to help out my buddy. He got canned last Friday when the company he worked for decided to contract out the shop work. We gota go get his service truck. Adios for now.
