Akpilot wrote:
Hoser,
The Polaris Liberty engines have oil pumps that dedicate 2 oil lines for the mag and PTO bearings that deliver oil slowly. One would only need to power the oil pump and drill access holes. Polaris uses a banjo style, and barb style, one way fitting for the oil lines just above the bearings.
Now skidoo uses Isoflex grease on the outer bearing as it is always starved for oil in their engines. Maybe pack grease on the seal side of the bearing?
I can only assume the Pilot
motor ((
Internal Combustion Engine ? )) ((Internal Combustion Engine?)) uses a hole drilled in the top of the case and relys on oil from the transfer ports for oil runoff to oil the bearings. Does port and polish magnify this problem? At
WOT (Wide Open Throttle) the mixture is moving too fast and not sticiking to the walls of the transfer ports. Not sure how to correct this maybe a windage tray to catch and drip more oil over the bearings - would be counter productive to port work tho.
Ak
Hi
I assume the oil systems your talking about use a mechanical pump of some sort to pump the oil?
I have 3 to 4 of the mechanical driven skidoo pumps that were driven off the rotary valves I don't want the complications of trying to figure out a way to drive a mechanical pump, right now I am going to try a vacuum driven fuel pump.
I don't polish anything inside a Engine fact is when I am done I run a special tool I made over the surfaces to put a rough texture inside the whole cylinder I don't do much for the texture in the crank cases, I rough up the surface rather than polish the surface simply because of the thickness of the boundary layer on a rough surface is THINNER than the boundary layer on a smooth surface, you have a limited space inside a Engine so the THINNER the boundary layer the more flow you get.
Too many get confused and like to see nice shiny smooth polished parts, research boundary layer I read about a dozen SAE docs and a whole bunch of other tech stuff that explains it will I never post the info because it takes about 20 to 30 hrs to read and most you have to read 2 to 3 times to understand it, mainly I never post the info because most people have bling and polished on the brain and just cant purge it out of their brains so I would just be wasting my time trying to share the info, its fun watching them trying to jet temperamental polished engines and being slower than me
Where their is no SPACE CONSTRAINTS a smooth polished surface like on a airplane wing where you have MILES OF SPACE above and below the wing is better the boundary layer can be 3' thick and it cost you nothing, adding .040 thickness to the boundary layers inside you Engine is huge
Always get a good laugh after seeing someone waste a day putting a pretty polish on Engine internals but pretty sells and pays huge psychological gains.
I have thought about drilling a passage and installing a grease zerk for the clutch side bearing and greasing with the Isoflex grease, just give it a fresh pump of grease after every 4 tanks of gas? or so? but I don't know enough about the grease to try it, if the grease is used in a unsealed environment like inside the Pilot Engine does it all wash out when the fuel or heat reaches the grease, will a chunk of grease get in the rings and gum them up, will a chunk of grease get on the plug and kill the spark, so many questions.
After my Pilot Engine killed its second clutch side bearing I asked around about installing a sealed both sides bearing on the clutch side, by time the seals wore out and the grease leaked out I figured their would be a nice build up of oil between the bearing and the clutch side seal to lube it, again too many unknowns.
Every Pilot Engine I rebuild I "hoserize the cases" I remove all the rough edges around the oil feed holes for the bearings I also enlarge the holes, bevel it really good I open up the area where the bearings and the seal and the oil feed hole all come together so their is less restriction than came from the factory.
All that being said maybe its a simple as going to 20:1 or 18:1 with the oil ratio?
I would rather have a oil pump feeding extra oil right to the deep groove of the bearing, dispensing the oil between the clutch side seal and the bearing itself.
Your thoughts? Especially on a sealed bearing or a grease zerk and greasing every once and a while.
