It is currently Mon May 19, 2025 10:05 pm
 Post subject: Finished my leak tester.
PostPosted: Thu Aug 30, 2012 1:57 pm
Got the rest if my bits to build my my leak tester today. Here's how it looks:
Here's what it's made up from:
1 metre 3mm vacuum hose
1 metre 6mm vacuum hose
1/4" female brass tee
1/4" male thread 6mm hose fitting
1/4" male thread 3mm hose fitting.
0-15 psi gauge 1/4" thread
Rubber hand pump from blood pressure monitor
45mm Expanding bung for exhaust port
38mm plug for intake.
The 3mm hose fits onto the pulse fitting on the head as you can see in the picture, 3mm is a nice fit to prevent any leaks.
For anyone who has done this test before i was wondering what pressure and time is suitable for a pilot and if you have any tips etc. Im planning on testing at 6lbs for 6mins.
I'll update the thread when I test it out.
Thanks,
David
PostPosted: Thu Aug 30, 2012 10:30 pm
I'm happy with the MityVac 8500 kit I bought off ebay. PVC plug for the intake, expanding plug for the exhaust, and tube to the vac nipple on the Engine. Easy.
PostPosted: Thu Aug 30, 2012 10:56 pm
I am curious if the tubing will leak where the gauge is placed in line. Are those the type of fittings that just press into the fitting without ferrells? I had those on my air bags on my truck and they did nothing but leak after about a month.
I hope they work well for you. I like the design.....simplistic!
PostPosted: Fri Aug 31, 2012 2:15 am
Hi Rand,
Its these type of fittings:
I blanked one end of the tube and pumped it up to 10psi with the lower two fitting under water without any leak. Ill make sure and check it for leaks when i next use it. thanks for the heads up.
David
PostPosted: Fri Aug 31, 2012 6:39 am
My homemade tester uses the push-type quick connects with nylon tubing, and its 100% leak free. We use them I'm $100k equipment, so I assumed they're good. :)
PostPosted: Fri Aug 31, 2012 10:23 am
Nice tester job well done you should fab and sell kits :-)
PostPosted: Sun Sep 02, 2012 2:16 pm
I like the tester as well. I did the retarded thing of buying a leak down tester from numb nuts at chucklenuts at aftershot motorspurts motorsports and had to rebuild the whole kit because it didn't last two tests before failing!!
PostPosted: Sun Sep 09, 2012 10:51 pm
Thanks Hoser, I'll see how it performs and if it works out ok i wouldn't mind making them up, just the shipping from the UK to the USA would be pricy i would imagine.
Thanks Cruz, I got all the bits needed to make mine from ebay cost less than $30.00
PostPosted: Sat Sep 15, 2012 1:47 pm
Used my leak tester today and it worked perfectly!
The Engine held 6psi for over 30mins so no problems with that.
Here's a few pictures with it rigged up.
David
PostPosted: Sat Sep 15, 2012 1:56 pm
Nice work
PostPosted: Wed Sep 19, 2012 10:09 am
Nice job Dave.
Looking at your Engine pics,why does the LHS front(from driver's posi) cyl to crank case stud,have twice as much NUT protrusion as the other?
Is it torqued all the way down/in?
PostPosted: Wed Sep 19, 2012 10:44 am
Hi Bugeye,
I never noticed the extra protrusion, well spotted.
Its definately torqued, maybe the stud moved a little on removal.
I will removed the nut and make sure the stud is completely home.
David
PostPosted: Sun Nov 18, 2012 9:09 pm
Thanks for the help Nick.....I will what I can come with on making making something work. I do have a mighty vac also as someone said they used that.
PostPosted: Thu Jul 18, 2013 10:15 pm
Hey Guys,
I have just sold my pilot and thought i would give somone the chance of my leak tester. If anyone wants it let me know, If you just cover the postage i would be happy.
PostPosted: Thu Jul 18, 2013 10:52 pm
pm sent
