It is currently Wed May 21, 2025 12:45 pm
 Post subject: Removing Fl350 starter
PostPosted: Thu Feb 27, 2014 3:55 am
Hi fellas. Just wondering: Is it posssible to remove and replace the Odyssey Fl350 starter without first removing the gas tank? Would appreciate any feedback/experiennce from anyone who's done it or tried to do it can offer.Thanks.
PostPosted: Thu Feb 27, 2014 4:38 am
Not gona happen. You have to get the rear bracket off the starter to get it out and the only way to do that is to pull your drive clutch. Why would you remove the gas tank ??
PostPosted: Thu Feb 27, 2014 4:46 am
The Official Honda Manual says its necessary to remove the gas tank to remove the starter. Have you removed the starter without taking out the stock gas tank first?
PostPosted: Thu Feb 27, 2014 4:50 am
Sorry my bad. It's late.
Yes you will have to remove the gas tank because two of the long bolts go through outside cover and into the starter to hold it. You will also have to pull the drive clutch to get two bolts out of the rear bracket holding the starter.
PostPosted: Thu Feb 27, 2014 4:59 am
Got it. Thanks for the info
PostPosted: Thu Feb 27, 2014 12:35 pm
I was able to remove my starter without removing the primary or secondary clutch. I did not take off that braket, just loosened it enough the starter would go past it at an angle once pulled out.
I unbolted the disk brake and moved it back. And you can get to the bolts on the starter mounting bracket with a combination wrench with the clutch still on.
Fuel tank needs to come out too. Need to take the gas cap off to get it out of the framerails.
PostPosted: Thu Feb 27, 2014 3:22 pm
Thnks for that useful info duwem. Anything to save time/morr work is appreciated.
