It is currently Mon Apr 29, 2024 9:35 pm
 Post subject: fl250 power loss
PostPosted: Wed Jun 15, 2005 7:50 am
I recently purchased an fl250. After approximately five minutes of riding, it acts as though it is running out of fuel. After setting a couple of minutes it runs fine for about another five minutes. It seems like a vapor lock kind of condition?? Any insight would be appreciated. I am new to this kind of thing. Thanks for your response.
 Post subject: Re: fl250 power loss
PostPosted: Wed Jun 15, 2005 1:18 pm
are you sure its not getting too much fuel? when i rebuilt my carb, i didnt tighten everything down, and some things came loose and caused that to happen
to see if its getting too much fuel, when it starts to do that, shut off the fuel valve and see if it runs better
and does it just die?
PostPosted: Wed Jun 15, 2005 6:16 pm
Check the fuel filter and check the gas tank for rust. That would be a good starting place.
Registered users: Bing [Bot], Google [Bot], Gootjr, wyeeoddy
