canadian oddy wrote:
ZeroClient wrote:
I have a bunch of spare axle parts that are on their way/out or whatever. What happens from what I can tell if the needle bearings get all crud and rust from lack of lubrication. From there the axle may still hold up well but eventually the U-Joint will start to wear down, and then cap as well. When it gets too sloppy the cap can start to crack or split. That's about all the info I have as I don't know what happens after that other than more slack and then major damage.
Thanks for the reply.
If you get one that grenades take a pic and post.
I still want to see the real thing.
I had a busted up one but I cut it up for parts
Pretty much the cups break apart then it blows apart
I had a broken one and the center Yoke was still good I used it on my rotax odyssey when I rebuilt the axles anhit was still working great
