It is currently Thu Apr 25, 2024 1:25 am
PostPosted: Wed Mar 08, 2017 12:54 am
Just got a hand me down yet FREE fl350. It's pretty rough so going through motor (( Internal Combustion Engine ? )) first to test starting power. I noticed the choke cable was not connected to carb. I cleaned the carb and jets and need to know how or if I need the cable connected again? Currently there is a big bolt in choke hole to close off port. Help appreciated and will keep perusing the site for more details of help!
Michael
PostPosted: Wed Mar 08, 2017 2:09 am
Welcome to the madness!
Pictures of the carb please.
PostPosted: Wed Mar 08, 2017 3:24 am
Welcome new guy.
I agree with Randman.
You need to post pictures so that we can all see what you got and give advice. Hard to do that when we can't see it. There are many things to check before you even start it, in my opinion. Would hate to see you blow it up and then have to spend a bunch of money on a free machine. First I would like to know how much mechanical ability you got ?? That would tell me a lot about the advice I would give you. When I post stuff here I am just azzuming you are a mechanic and know what you are doing. If I know you are new at it then I can adjust my advice.
PostPosted: Wed Mar 08, 2017 6:06 pm
Thanks Randman and Can Oddy. Didn't think that through before adding post about pics and past experience. I will get some pics up tomorrow and post and we go from there.
I have little to moderate mechanical know how. I can read and follow YouTube vids, read schematics and manuals, -!: have actually maintained a hand me down ford 8n tractor. So I can do things, just have to figure it out. Thanks guys!
PostPosted: Wed Mar 08, 2017 7:17 pm
Well then based on what you have just said, here is a list to read. It is all the things you need to check before you even start it again. Trust me, I am not making this up out of thin air. I blew nine engines in a row before I figured it all out. Most of the time it did not run 100yrds and booooooom, honest. Others here will back me up. Check and fix ALL the things below and you are good.
Here is my list of things to check on an oddy when you are doing an Engine job or just purchased one.
1) Fuel - your fuel pump must put out about 4.5 oz/ten seconds and your fuel must meet at least the minimum octane rating in manual. I run straight avgas or you can mix it 50/50 with pump fuel.
2) Do the vent modification (optional but recommended) use the search box above.
5) Engine MUST pass pressure and vacuum test - if it doesn't don't even start it, find the leak. I use 10psi max pressure and 10in vacuum in my tests and it must hold for half hour minimum.
6) Rebuild the starter, it is a big job after the Engine is in.
10) Check the wheel bearings.
Using the search box above to find stuff:
In the search box type ONE word only and hit enter. If you don't you will get to many hits.
In that box type ONE word only. Keep doing this as many times as you want until you have narrowed it down. Some common words will be ignored like "Engine" "Honda" etc.
PostPosted: Wed Mar 08, 2017 7:24 pm
Many very knowledgeable and good people here on this site, Randman one of them. Most of us are middle aged and are mechanics or other highly qualified trades or business people. One of our members actually works for Honda but only shows up once in a while. We have people from all over the world here, French, Costa Rica, Aussie, Canadian, American. Lots of info on this site. Use the search box.
PostPosted: Wed Mar 08, 2017 8:36 pm
holy crap Oddy, that's a lot of crap! I don't have a clue about the compression test or pressure stuff, never done any of that. inside gas tank look ok, and that's about all I can tell you. no idea how or what u joints do, so that will be a study up. Thanks for the heads up and I will keep you posted.
can I just add fuel, spark and battery to get it running, then go from there? as soon as I got it I did connect a battery to it and the motor (( Internal Combustion Engine ? )) does turn over, no gas in it though at time. I need new tires all around and I know the e brake is stuck in the "on" position by my terms. so going to that next, checking brakes as brake levers don't really pull in at all right now on the steering wheel.
I haven't look over site yet but I did see a all you want to know about oddy's post, and is there a odyssey newbie discussion or odyssey 101?
Thanks again for your help!!
Michael
PostPosted: Wed Mar 08, 2017 8:44 pm
Remember that your Engine is lubricated by the oil mixed with your fuel. If the Engine leans out due to air leak or faulty fuel filter it is not getting lubed properly and that is not good. Can't think of it like a four stroke Engine with oil in the crankcase. Make sure you use a good quality premix 2 cycle oil. None of that cheep weed eater oil. I run golden spectrum. I buy high octane fuel. Most gas stations call it premium.
Take your time and ask any question you have.
PostPosted: Wed Mar 08, 2017 9:05 pm
can I just add fuel, spark and battery to get it running, then go from there? as soon as I got it I did connect a battery to it and the motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )) does turn over, no gas in it though at time. I need new tires all around and I know the e brake is stuck in the "on" position by my terms. so going to that next, checking brakes as brake levers don't really pull in at all right now on the steering wheel.
Michael
LOL, this is what i thought eight years ago when I got into the Pilot Odyssey 2 stroke Engine hobby. I wanted to just put gas in and go, but i soon learned these guys know what they are talking about and the 2 stroke Engine really need the TLC before getting in and running it like you stole it. Good luck with the new machine!!
PostPosted: Wed Mar 08, 2017 10:56 pm
NO
PostPosted: Thu Mar 09, 2017 11:27 am
Well turns out I have everything I need! The cable nut was packed with mud, so cleaned mud out and that is where the cable would go in then covered with the rubber boot.
File comment: Top view
File comment: Side view
File comment: Carb choke
File comment: Choke cable
PostPosted: Thu Mar 09, 2017 12:03 pm
I STRONGLY advise that you tear that carb down and soak it in a good quality cleaner for a few hours before going any farther. It's probably full of crap and it will give you fits when you try to get the Ody running properly.
PostPosted: Fri Mar 10, 2017 12:31 am
I did learn and watch vids about cleaning carb and performed a good cleaning, didn't soak it as I didn't want to spend $27 for a gallon of cleaner I might use once! Honey looking crap all in the bottom of carb and jets were stopped solid. New fuel filters and spark plug and fires right up in a few starts. Did not have any intent of going anywhere with it, but just to start it. When I did pop it in gear forwards backwards it's didn't budge. Next thing is brakes and go one step at a time. I know the front brake handle doesn't move a bit, and the e brake cable doesn't move at all and the brake is in engaged mode.
PostPosted: Fri Mar 10, 2017 12:52 am
I don't know if you got a manual for it but you can get a FREE pdf here: http://oddatv.com/fl250-fl350-factory-manuals/
PostPosted: Fri Mar 10, 2017 1:26 am
Good ol fashioned Pine Sol is cheap and cleans the carb parts amazingly
PostPosted: Fri Mar 10, 2017 1:34 am
Thanks oddy, have turned to that many times already
PostPosted: Fri Mar 10, 2017 1:49 am
Here is the pdf of the parts book with part numbers.
Keep in mind that a lot of that stuff you can't get anymore but it is available online at various places.
Note: don't order anything from Hondapartshouse if you can help it. Those guys are fkn clowns.
fl350 parts book.pdf [2.35 MiB]
Downloaded 79 times
PostPosted: Fri Mar 10, 2017 2:37 pm
Post a few pics of your machine from all sides and we can tell you what we see is wrong. That's what we do here. It is not that we are being nasty, its just so that you can fix what we see is wrong -- or not, up to you.
PostPosted: Sat Mar 11, 2017 4:43 pm
Any particular shots in recommended? Wheels on/off for. Takes, u joint pics? Well if I am questioning these I may just show you anyway. Best thread to post them on?
PostPosted: Sat Mar 11, 2017 5:04 pm
Post the pics here. What ever you want to show.
You can only load 6 pics (I think) at a time. Then you have to go out, then you can load six more.
