Shift linkage http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=17327 |
Page 1 of 1 |
Author: | Yatesmotorsports [ Wed Mar 15, 2017 9:46 pm ] |
Post subject: | Shift linkage |
Is there any special trick to taking the linkage off of the shaft coming out of the transmission? I took the bolt all the way out but it still does not want to come off |
Author: | rmesser [ Wed Mar 15, 2017 10:19 pm ] |
Post subject: | Re: Shift linkage |
Have you tried to spread it apart gently at the slot where the bolt goes through? You have to remove the bolt as it engages a slot in the shaft. You working on a fl400 or fl350? Are you servicing your gearbox? |
Author: | Yatesmotorsports [ Thu Mar 16, 2017 12:56 am ] |
Sorry. Project 350. I will try that tomorrow. I'm trying to figure out if the cables are froze or if there is something bigger |
Author: | Yatesmotorsports [ Thu Mar 16, 2017 2:23 pm ] |
Got it off. It was slightly bent so it was tough. Thanks for the input |
