It is currently Tue Apr 16, 2024 2:58 pm
 Post subject: 81 Fl250 Won't run
PostPosted: Sat Apr 08, 2017 9:50 pm
Spin motor (( Internal Combustion Engine ? )), have spark at black/red wire on CDI (Capacitor Discharge Ignition) unit coming from motor (( Internal Combustion Engine ? )). Also black wire. But nothing coming back out of CDI (Capacitor Discharge Ignition) unit going to coil via the blue/ yellow wire. I have checked all wires, compared to service manual, replaced CDI (Capacitor Discharge Ignition) unit. Still nothing. What am I missing?
 Post subject: Re: 81 Fl250 Won't run
PostPosted: Sun Apr 09, 2017 12:47 am
Rednartso2 wrote:
Spin motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )), have spark at black/red wire on CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition) unit coming from motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )). Also black wire. But nothing coming back out of CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition) unit going to coil via the blue/ yellow wire. I have checked all wires, compared to service manual, replaced CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition) unit. Still nothing. What am I missing?
I am not an expert on the FL250 or an electrical guy but there must be a pickup coil near the flywheel. Is the gap correct ??
PostPosted: Sun Apr 09, 2017 12:48 am
Are you sure your other CDI (Capacitor Discharge Ignition) is good ??
The CDI (Capacitor Discharge Ignition)'s are very reliable but just a thought.
By the way welcome new guy.
PostPosted: Sun Apr 09, 2017 12:52 am
It's the correct flywheel right ??
All grounds are in good shape at mounting point on frame (not rusted up)??
Try bypassing the kill switch to confirm it is not that. Use a jumper wire on the switch.
PostPosted: Sun Apr 09, 2017 1:06 am
Here is a little something something I found and will pass on: viewtopic.php?f=63&t=9195
PostPosted: Sun Apr 09, 2017 1:07 am
Also look at the very bottom of this page. There are a lot of similar topics to your issue. Click on them and read away. Good luck.
PostPosted: Sun Apr 09, 2017 2:23 pm
Have changed CDI (Capacitor Discharge Ignition) with known good unit. When spin motor (( Internal Combustion Engine ? )) and have test light hooked to Black/ red wire from motor (( Internal Combustion Engine ? )) it lights the light. Hook CDI (Capacitor Discharge Ignition) back up and have nothing coming back out of box. Hook test light to kill switch black wire and spin motor (( Internal Combustion Engine ? )), light flashes. Other wire is green which is green so would ground system.
PostPosted: Sun Apr 09, 2017 3:00 pm
Well according to the wiring diagram I got, the green wire from Engine is not a ground. In the pic below you can see that the green wire from Engine goes into the CDI (Capacitor Discharge Ignition) box. Am I reading this wrong ?? I am not an electrician so may be I am wrong but that's what I see.
EDIT: Never mind your right it is ground. That's why I am not an electrician and why I hate electrical work.
PostPosted: Sun Apr 09, 2017 3:04 pm
I wonder if someone butchered the wiring somewhere and hooked up two colors wrong in a splice job.
Broken wire or connection some place ??
Just had a thought (sometimes that's bad), I read a thread once where the kill switch was working backwards on an FL250. Off was on and ON was off. Just for fun try it.
EDIT: Unplug the kill switch all together to make sure it is not grounding and try it.
PostPosted: Sun Apr 09, 2017 4:35 pm
The way I see it, it can only be 5 things:
1) CDI (Capacitor Discharge Ignition) unit -- nope you said it was good
2) Kill switch -- unplug it and try
3) Alternator/Generator -- nope you got light
4) Pick up coil not triggering CDI (Capacitor Discharge Ignition) -- possibly
5) Broken wire or butcher job on harness
PostPosted: Sun Apr 09, 2017 4:49 pm
All great ideas. I unhooked all wires except the one from motor (( Internal Combustion Engine ? )) to CDI (Capacitor Discharge Ignition). Wiring looks good but eliminated​it all. I'm wondering now if yes my test light is showing a circuit but is it possible I'm not getting enough juice from the motor (( Internal Combustion Engine ? )) to actually fire the CDI (Capacitor Discharge Ignition) and then coil?
PostPosted: Sun Apr 09, 2017 9:02 pm
Rednartso2 wrote:
All great ideas. I unhooked all wires except the one from motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )) to CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition). Wiring looks good but eliminated​it all. I'm wondering now if yes my test light is showing a circuit but is it possible I'm not getting enough juice from the motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )) to actually fire the CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition) and then coil?
According to that drawing there are two wires sending juice to the CDI (Capacitor Discharge Ignition). Blue/Yellow which would be the trigger and Black/Red for coil juice. One green for ground. These three must be hooked up. If you are getting juice from the Black/Red then the Blue/Yellow must not be triggering the CDI (Capacitor Discharge Ignition). Are you getting light from the Blue/Yellow ??
PostPosted: Sun Apr 09, 2017 10:07 pm
No I'm not. I'm​going to pull flywheel and see what I can see. I should be getting pulse at both correct.
PostPosted: Sun Apr 09, 2017 10:24 pm
That's what I would think -- pulse at both wires
You may not need to pull flywheel. Check the gap between pulse coil and the flywheel. It should be in the manual. If it is correct then pull flywheel and see if the key is sheared.
PostPosted: Sun Apr 09, 2017 10:58 pm
I could not find a gap measurement in either of the manuals. So I took apart a spare FL350 Engine and measured the gap between the flywheel and the pulse coil. It came in at .035". So I would say that if you are in that range plus/minus then your golden.
PostPosted: Mon Apr 10, 2017 12:09 am
Scratch that idea. I think the FL250 has the pulse coil under the flywheel and the FL350 has is on the outside.
PostPosted: Sat Apr 22, 2017 5:55 pm
Pulled rotor. Cleaned magnets, everything up. Put back together, spun Engine, still no spark at pulse wire. Is there a way to test it?
PostPosted: Sat Apr 22, 2017 6:04 pm
I am not an electrician but the way I see it, as long as the ground wire has a clean contact and you spin the flywheel by it, it should cause a spark. If it don't then it's shot. We need an electrical guy like adnoh to chime in here.
PostPosted: Sun Apr 23, 2017 1:46 am
Hook a multimeter to that wire and see if you are getting any voltage when you spin it over. Will be less than 12v for sure but not really sure what that voltage should be. See if it says anything in the manual about it.
PostPosted: Tue May 30, 2017 4:23 pm
Checked ohms compared to manual. Exciter coil is 215. Pulse coil is 45. Spun motor (( Internal Combustion Engine ? )) with drill and volt meter hooked to pulse wire and did show a couple bolts. Going to mount it all back into the buggy and hook back up. I've changed everything. I've checked everything. If I don't get spark now it might be for sale.
PostPosted: Tue May 30, 2017 6:21 pm
This might sound really stupid but is there a ground wire attached to the Engine ??
I say this because the Engine has rubber mounts and no way for sparkplug to ground unless there is some kind of wire to ground.
PostPosted: Tue May 30, 2017 7:19 pm
Not stupid at all. I added a wire from the motor (( Internal Combustion Engine ? )) to the frame. Has the ground wire in the harness that hooks to the coil and one that bolts to roll cage. I'm baffled.
Registered users: Bing [Bot], chorizofingers, Google [Bot], Lanix, liduno
