Know we can look at the other vertical scuffing marks of the cylinder walls as they tell a great story. By the way hats off the machinist on your cylinder.
The Wiseco or stock piston (Arts) for that matter when which would have failed sooner form this event. Shows a great story line all the way trough failure on most parts of the
Engine as and there relation ship to heat dissipation for combustion. The pictures does show signs of cylinder scuffing. We must look at this very carefully to make determine from what we see.
As a general reference scuffing one item against another. The visual is material one to another. Now why or what ?
In our case we pretty darn sure the what, is Aluminum to Steel transfer. The why is much greater item to distinguish.
For this we conclude one,two or three things or all three items in succession.
#1 lack of distance from materials
#2 lack of lubricant to act as a barrier between the two metals
#3 The expansion rate of the two metals for heat.
We know the original static distance was ok. We know the amount and quality of lubricant was ok. What we don't know was the rate of expansion for the two metals. We can however conclude the rate at some point was not acceptable due the fact there was scuffing.
For this we look at the cylinder and the piston to tell the story. For me the key is the scuffing lines on the cylinder.
This tells me the piston crown has seen excessive heat which was absorbed down the piston into the boss area. wen this happens due to the shear mass of that area it swells outward with less flex like a the skirt of the piston. The amount of this scuff also tells me the event was quick. If the event would have taken a longer period of time the scuffing would have been greater as well as the piston crowns edge would have started to let go.
If you look at the exhaust side pic I highlighted a area that can be referenced back to piston crown pic and offer as evidence of that statement. The area above that is shinny, above this high lighted area can be measured and turned into a degrees of timing.
I must go for know so thank you for allowing me to comment.
Adnoh
