It is currently Mon May 06, 2024 10:29 pm
 Post subject: Roll bar thickness
PostPosted: Mon Apr 03, 2017 1:35 am
I don't know if anyone is interested but since I am cutting apart a damaged roll bar on my crashed oddy, I decided to measure the wall thickness for anyone's future reference.
The wall thickness is .100
Also anytime I have cut or welded on these frames it is obvious that it is galvanized.
 Post subject: Re: Roll bar thickness
PostPosted: Mon Apr 03, 2017 6:41 am
Not sure if its galvanized or just a zinc coating but I noticed the inside of ATC250R and Pilot frame tubing has a gray coating assume its to prevent rusting out.
Thought the Pilot tube was .065 would have to measure again to verify.
PostPosted: Mon Apr 10, 2017 1:07 pm
what is the bar diameter? OD? I keep forgetting to go measure mine.
PostPosted: Mon Apr 10, 2017 2:51 pm
Top roll cage has two different size tubes.
Main roll hoop is 1.500" OD
Other is 1.260" OD
