It is currently Thu Apr 25, 2024 8:24 pm
 Post subject: Steering good/bad
PostPosted: Sat May 13, 2017 2:41 pm
So I tried to be as informed as possible before I post on here with all you smart guys! So my steering to left is HORRIBLE, turning right is way better and on par with the 15' radius I read about for odysseys. I snapped a few pics of steering wheel straight so you can see camber and toe in/out. I really don't know much about this topic, so any guidance as usual will be much accepted! Added back view for any opinions on back tire stance issues.
Thanks Michael
 Post subject: Re: Steering good/bad
PostPosted: Sat May 13, 2017 2:57 pm
Re-posted your pics straight
PostPosted: Sat May 13, 2017 3:05 pm
Based on what I see there:
1) Your front right tire has a bad camber. That tells me that your top J-arm bushings are probably gone. Could also be a bent spindle.
2) The pic of the rear of your buggy seems to show a possible bent chassis but I don't know if it is the angle of the pic.
3) The right rear tire has camber but that is normal for these buggies because if you jump on the back end everything usually squares up, so not likely any issue here.
4) Also based on the pics you appear to be running the stock rims. The oddy turns better with wider offset front rims and the stock rear rims. This makes the chassis a bit more square which seems to help it turn. That's what we have found anyway, but it could be our driving style.
We also run 1" toe out at the front of our buggies.
PostPosted: Sat May 13, 2017 6:01 pm
Thanks Can Oddy for the pic adjust! Not quite sure I know how to adjust yet. I will look up the info for the top J arm bushing. Where do I find that info in the service manual? And also where do info about setting or correcting the toe?
Around my property I have no problem making most turns righty, just have to plan ahead and known my route or gas it to drift back end around.
And I do have the original gold colored rims on oddy.
PostPosted: Sat May 13, 2017 6:37 pm
It's in section 10 of the manual.
Section 10-14 shows the J-arm bushing measurement limits and replacement. I think speedchaser was making bushings for sale at one time. I make my own on my lathe out of UHMW.
Setting your toe adjustment. You do this by loosening the nuts on the steering rods to the wheel and turning the rod. One nut is a left hand thread and one nut is a right hand thread on each rod. First you need to find the center of the buggy at the front and make a mark with a pencil. That will be a reference mark for later. What you do is take two tape measurements from the center of the front tires. One at the back and one at the front. What is the difference ?? If the measurement is narrower at the back than the front then you have toe out. Once you have 1" toe out then measure from the center of each tire to your pencil mark. Are they same ?? If not then you have one wheel pointing out more than the other. Re-do it again until you have it right.
PostPosted: Sat May 13, 2017 6:42 pm
Looking again at the front wheel just screams the J-arm bushing is badly worn.
You also have no shock savers on the rear of that machine and if you blow a u-joint it will twist your shock into a pretzel. Also ditch those rear springs as you currently will have no suspension travel with the stock springs and will hurt your back. We run about 155LB springs right now. The stock ones are about 220LB and WAY TO STIFF.
PostPosted: Sun May 14, 2017 9:08 am
fuesselfc
Ok First up
With the front end looking at the pic the J arms look OK but there maybe some wear.
Jack up the front and lift the wheel up and down and look at for movement.
Take close attention to the wheel bearings first then look at the top and bottoms J arms
were they bolt to the on to the frame.
Yes you can do a bush replacement SEE member Speedchaser
He makes a nice bush replacement kit and a nice shim kit
Not sure if he still does then even a shim set might solve problem
Second which will make a big difference if there not right
The Tie RODs maybe you or the previous owners have had the Tie rods off
and may of not been refit correctly.
Make Sure the Left tie rod sits in the BOTTOM or the steering center or yoke and the rod sits
on TOP of the left steering Knuckle
Make sure the Right tie rod sits in the TOP of the steering center or yoke and then rod sits
on BOTTOM of the right steering Knuckle
see pic
I found that my steering was not flash turning left was cr@p and after reading and
checking I found the tie rods were WRONG and Yes it made a big difference
see pic attached check it first before doing the toe in/out
Third: Right rear wheel the top Adjuster need adjustment see attached pic
and the frame looks ok. I would measure the left side center to center on the mounting bolts and
mirror to the right.
NOTE This is What I have done.
I went and took the camber out at the top by a extra 2 to 3mm to help stop
the uni Joints bind at full compression.
Hope that helps
wyeeoddy
PostPosted: Sun May 14, 2017 2:45 pm
I havent heard of shock savers. where exactly would i find them? also don't know anything about shocks, so can you guide me to wear to find some to look up? Thanks again for the help!
PostPosted: Sun May 14, 2017 2:46 pm
So much good info weeoddy!! Thanks!
PostPosted: Sun May 14, 2017 3:17 pm
These are the ones I made for our machines. The chain must be the correct length or you will get binding. I forget the correct length right now but there is a thread on it. You can check if correct length by removing shock and cycle wheel up and down by hand after you have the chain on. This is one of the last mods you make after you fix other stuff like the vent mod.
Springs: you can get them online. Eibach makes good springs. https://www.kartek.com/parts-categories ... -tall.html
File comment: you need the tie bar on it like the first pic but I just showed this so you can see how it goes together
PostPosted: Sun May 14, 2017 9:11 pm
A lot of other really good info here along with part numbers: viewtopic.php?f=26&t=15392&hilit=danifold
PostPosted: Sun May 14, 2017 9:14 pm
Here is the list:
Here is my list of things to check on an oddy when you are doing an Engine job or bought one.
10) Check the wheel bearings.
14) Must build shock savers. Use the search box above.
15) Replace the rear springs with 155lbs units. Stock ones are way to stiff.
PostPosted: Sun May 14, 2017 10:44 pm
Is anything bent on your front end? Upper and/or lower spindles? Steering knuckle? Or tie rod?
My buggy has a similar camber to yours on the front. But my bushings appear to be OK, I believe the spindle is slightly bent backwards. The tie rod was bent on that side, and the steering knuckle "stop" was bent. This tells me mine had a serious impact on that tire.
PostPosted: Mon May 15, 2017 2:22 am
Here is the thread on the chain length: viewtopic.php?f=1&t=15745&hilit=shock+saver+chain
PostPosted: Wed May 17, 2017 10:47 pm
Not sure what you're running - oddy or pilot but check this out. May help
viewtopic.php?f=1&t=17023
PostPosted: Wed May 17, 2017 11:23 pm
Thanks for the link. That's how mine looks too. I'll prob grab a new spindle and try that out.
OH, and mine is on an Oddy. Thanks again
PostPosted: Thu May 18, 2017 2:25 am
Canadian oddy
I know this is off topic
in pic 20150205_212353.jpg which shows the back of your oddy.
I see you have attached the fuel supply to the drain plug
1./ NO reserve
2./ Very exposed
3./ Break the nipple off and your pushing it home
PostPosted: Thu May 18, 2017 3:38 am
wyeeoddy wrote:
Canadian oddy
1./ NO reserve
2./ Very exposed
Good eye.
Yes sir to all of your points but with explanation:
1) Where we ride if you are on the reserve your not getting home anyways
2) Yes a bit exposed but nipple is just poking out of the skid shield
3) Correct but we never ride alone -- way to dangerous if you need a helicopter ride to the hospital
Basically both tanks had issues when I bought the machines. Both tanks had plugged or broken off screens inside. One tank had the main line broke off inside the tank WTF how did the yoyo do that ??
So the easiest solution for me was to tap the drain plug. I welded a nipple onto the screw in part so that the pickup was just off the bottom about 3/16". With regards to snapping off a nipple that is a concern but the tank is high up with a skid shield and most of the nipple is protected. We take our chances but have not had an issue yet and have had some horrendous crashes and mechanical failures.
Registered users: Bing [Bot], chorizofingers, Google [Bot], Google Feedfetcher, Lanix
