It is currently Thu Mar 28, 2024 8:10 am
 Post subject: fl250 bottom end
PostPosted: Wed Aug 23, 2017 10:19 pm
What is the best way to put seals and bearings into the bottom end of an Fl250 bottom end. Ive heard freeze the seals and bearing then it only takes some light tapping to get them seated.
 Post subject: Re: fl250 bottom end
PostPosted: Wed Aug 23, 2017 10:23 pm
I have heard and done freeze the bearing but never heard of freeze the seal.
PostPosted: Thu Aug 24, 2017 8:53 am
whats the best way to install the seals?
PostPosted: Thu Aug 24, 2017 10:29 am
There are many ways to do it but the proper way is with a seal tool.
I doubt anyone has one of these laying in their shop. Basically it is a piece of round stock machined to fit into the inside of the seal and has a large flat that fits onto the outside of the seal correctly. Then you smack it or press it with a clamp.
That's not how I do it.
I am a hack n whack guy and have not had any issues ever with the way I install seals at home or at work.
1) You get a piece of steel that you can lay on the outside of the seal. Get a clamp and press it in. Everything must be square when you do it. This works fine if you can get at it.
2) The way I do it: Just get a FN hammer and "tap" the edges of the seal in a circular pattern until the seal is in the home position. You don't want the seal to go in crooked so it will require many "taps" to get it there. NO gorilla hits, use a brain. It may require a few hard taps at the very start to get the seal to take a set, but use common sense. You could use the piece of steel method above and your hammer instead of a clamp to get it started. Never had an issue doing this.
PostPosted: Thu Aug 24, 2017 11:16 am
Lookup "crankshaft oil seal install" on youtube.
https://www.google.com/search?q=installing+a+crank+seal&safe=off&rlz=1C1NHXL_enUS715US715&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjW3NbdlPDVAhUEzoMKHbj2B4kQ_AUICigB&biw=1600&bih=810
