It is currently Fri Apr 19, 2024 2:00 pm
 Post subject: Pull start question
PostPosted: Sun Dec 17, 2017 9:29 pm
Hello been a member for a while just never owned a odyssey. Now I do bought what I believe is a 79 and a roller of a 80s model and a half of another 70s model. The 79 has almost complete motor (( Internal Combustion Engine ? )) except for the rubber intake boot after carb.
The problem I'm having is the pull start was sprung. In the manual it says to roll the cord around then compress spring with two and a half turns. I understand but I still have the original Honda handle and the cord will not come out of the handle has anyone else had this problem?
Thanks. sorry guys problem solved .
 Post subject: Re: Pull start question
PostPosted: Sun Dec 17, 2017 10:44 pm
Wow 2008 and this is your first post :shock: .
Just because you didn't own an oddy at the time you could still post.
Any other info you need ?? Or have you been trolling all these years collecting data :-) .
Anyways welcome back.
