PilotOdyssey.com
What is required to wire for a charging system?
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=17870
Page 1 of 1
Author:  Superlite_Don [ Tue Jan 30, 2018 10:14 pm ]
Post subject:  What is required to wire for a charging system?
The guy restoring my car is adding the charging system (I never used one). He does not have an FL350 harness, but has the regulator/rectifier and the charging coil. So I know the yellows goes to the yellows, the green from the alternator to the green on the regulator and also to ground. And the red/white to the + on the battery. But is the black wire on the regulator needed? Just not sure what it does.
Author:  scpilot66 [ Tue Jan 30, 2018 10:33 pm ]
Post subject:  Re: What is required to wire for a charging system?
I would need to check the manual but from memory I think that is the key on power wire.
I can check here in a bit if needed.
Author:  Superlite_Don [ Tue Jan 30, 2018 10:57 pm ]
That is what it looks like. Is it needed for the charging system to work correctly? Does that mean it just gets switched +12V? I appreciate the help when you get the chance.
Don
Author:  scpilot66 [ Tue Jan 30, 2018 11:31 pm ]
OK just checked, yes black is key on power +12v and yes you need it.
Do not leave the black wire powered all the time, a toggle switch is fine if you do not have an ignition switch.
On your red/white wire be sure to run a 15 amp fuse inline.
Good luck, Steve.
Author:  canadian oddy [ Tue Jan 30, 2018 11:34 pm ]
I don't know if this will help you Don, but I have a color pdf file below if you need it.
I hate electrical.
wiring schematic.pdf [86.85 KiB]
Downloaded 55 times
Author:  canadian oddy [ Tue Jan 30, 2018 11:58 pm ]
I think this next pdf answers your question.
It is a Honda color code explanation.
It's for small motorcycles but I don't see why it wouldn't be the same for the atv's
hondawirecolorcodes.pdf [316.56 KiB]
Downloaded 60 times
Author:  Superlite_Don [ Wed Jan 31, 2018 10:17 pm ]
Great. You guys are the best.
Author:  Garemie [ Sat Sep 01, 2018 12:14 pm ]
Good luck, Steve.
Sorry to resurrect, but can someone explain this? I leave my ignition switch on all the time on my 350s, does this have some negative effect? I have never seen it drain the battery...yet....
https://www.phpbb.com/
