So I recently had the pleasure of opening two FL350 gear boxes. Played around with it for a little to figure out how the gear selector worked and such.
The first one had some gouges in the case & upon further inspection I noticed hairline cracks on the outside of the case. I assumed it was rebuilt at some point because original gasket was gone. I inspected all the gears and bearings / needle bearings and they all looked good.
While the second one was not as bad as the first, it did show signs of wear in the same spot. Again, I inspected all the gears and bearings / needle bearings and they all looked good.
What is the culprit of this?
