FL350 shock savers http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=18667 |
Page 1 of 1 |
Author: | Garemie [ Sun Jul 07, 2019 1:01 pm ] |
Post subject: | FL350 shock savers |
Has anyone had a u joint fail with shock savers installed? Reason I ask is that I'm having a hard time figuring out if they will actually benefit in reality. If it fails on an inside corner, the wheel would fall in toward the center, correct? |
Author: | canadian oddy [ Sun Jul 07, 2019 2:48 pm ] | |||||||
Post subject: | Re: FL350 shock savers | |||||||
Garemie wrote: Has anyone had a u joint fail with shock savers installed? Reason I ask is that I'm having a hard time figuring out if they will actually benefit in reality. If it fails on an inside corner, the wheel would fall in toward the center, correct? I think you are missing the theory here. They are called "SHOCK savers". When you blow a u joint it will take out your shock every time without these shock savers installed. We have had several incidents where these shock savers have saved me work and money. These shock savers also prevent you from doing damage to a u joint when something fails. See pics below. CO
Author: | Garemie [ Sun Jul 07, 2019 4:33 pm ] |
Thanks for the pics. Definitely clarified things for me. |
