It is currently Thu May 15, 2025 12:38 am
PostPosted: Thu Jan 02, 2020 5:52 am
So I’m an idiot and i was doing a rebuild to the top end of my fl350 Engine and left the crankcase open and it rained and now it’s full of water, I opened the drain but it didn’t drain it
What do i do?
PostPosted: Thu Jan 02, 2020 6:56 am
Your drain plug will only drain oil from your balancer gearside. There is no oil in the case as we mix oil with our gas = lubes the cylinder/case.
Pull the Engine out, dump the water out, fill with diesel fuel a few times and dump it out. This should flush any water out of the case.
-Curtis
PostPosted: Thu Jan 02, 2020 8:55 am
If the Engine is still in the machine, I’d take the top end off and get the wet/dry shop vac going. Suck out everything. WD40 also displaces water.
PostPosted: Fri Jan 03, 2020 3:52 am
thank you for your suggestions i ended up just blowing it with compressed air and got it all out
