That time of year again getting ready for a week away with the Oddy.
Last ride 2 months ago a quick squirt out the back of town. And the last big ride
the oddys idle was playing up. Pressure test while I was away No problem but still idle
problem and it went like it was on rockets fuel ( not that Hasgas stuff ).
3 days ago pressure test to 6psi and only lasted 5 mins to 0 psi
The Clutch side was done 3 years ago double lipped and outer and I have never had the Coil side
apart so I pulled the starter, Mag and Stater. pumped up the pressure tester to 4 psi and the seal popped
across the garage. The seal just about pushed in by hand so it was toast. the only thing that was keeping it
in was the stater plate.
pressured tested this arvo 6 Psi for 20min that was good enough re fitted
motor ((
Internal Combustion Engine ? )) hope to fire up mid week.
Wyeeoddy
