It is currently Mon May 19, 2025 5:45 am
 Post subject: Wiggens FMF silencer mod
PostPosted: Sun Apr 17, 2005 10:29 am
Here are some pics of the Wiggens FMF silencer modification.
The blue arrow is pointing towards the tab welded on to the pipe adapter,
the spring is the same spring used on the connection at the head pipe
and Engine, Honda part number 18332-430-700 $ 5.75 at Service Honda
pricy but I doubt you will find a better spring, most hardware store springs
loose their spring after being heated up a few times, the Honda springs
hold tension after hundreds of heat cycles.
PostPosted: Sun Apr 17, 2005 12:38 pm
you will like the quiet silencer
that sure is a pretty pipe. Is it chrome or coated with something :shock:
let us know how long it takes to turn to rust
PostPosted: Sun Apr 17, 2005 1:06 pm
The pipe is ceramic coated like the one on my wifes Pilot.
 Post subject: Re:
PostPosted: Wed Nov 18, 2020 4:08 pm
Where did this pipe come from Hoser? Looking for a new set up on mine as well, ATV motorsports in Phoenix has been unable to get them in stock.
 Post subject: Re: Re:
PostPosted: Thu Nov 19, 2020 9:57 pm
Hello, its been so long I really do not remember, check out this site search for FMF Silencer https://www.google.com/search?q=FMF+Sil ... dyssey.com
PostPosted: Fri Nov 20, 2020 2:26 am
Try here...
https://www.denniskirk.com/dirt-bike/mufflers-slip-ons
Good Luck
