It is currently Sat May 17, 2025 1:01 pm
PostPosted: Fri Jan 26, 2007 9:12 pm
Here is the FL350 Schematic in Color.
PDF format...
Wiring diagram
FL350_schematic.pdf [86.85 KiB]
Downloaded 529 times
PostPosted: Sun Jan 28, 2007 12:18 pm
Mass that a great thread, thanks very much for it, the time is must have taken you is greatly apprec, that is a really sweet download-a must for the 350 home-woods useage.
PostPosted: Sun Jan 28, 2007 12:26 pm
Thanks mud. Glad to share.
I started by copying the schematic from the on line manual.
I then drew over each component with Visio and created each of the parts and connection points.
Then I used the line tool to run the wires. To make the two coloered lines I use two lines one with the dashes ontop of a solid one which is the background color.
Then I moved the parts a bit to make line line up and be slightly easier to read.
Going forward I'd like to do the Pilot as well. And add hyperlinks so you can click on a part in the schematic and be brought to more information about it.
And the final step is to use Adobe Acrobat to create the PDF file.
PostPosted: Sun Jan 28, 2007 1:20 pm
Adding hyper links to include your as found resistance values in various parts of the system?
PostPosted: Sun Jan 28, 2007 3:51 pm
Mabye add as a footnote that tach harness you made up Mass for the pilot as well as the odyssey? would be cool to offer for the fellas.
PostPosted: Sun Jan 28, 2007 6:20 pm
OK will do both.
But yeah. a link to the testing of the part and click to get more details like the manual page.
PostPosted: Sun Jan 28, 2007 9:24 pm
killer sweet TY
