It is currently Thu May 15, 2025 12:49 am
PostPosted: Thu Apr 19, 2007 4:12 pm
http://cgi.ebay.com/ebaymotors
Item number: 330110353980 and Item number: 330110354450
Does anybody think this is worth the money? I have the 39mm mikuni pro flatslide and am wanting to buy the v-force 3 reed cage http://cgi.ebay.com/
My stock intake for the stock carb will fit the 39mm, it just has to be heated up to slide over it. If it were you, would you optimize for the new matched intake with the reeds or do without the intake?
P.S. these are a little cheaper on ebay than to go through after shock motor (( Internal Combustion Engine ? )) sports.
PostPosted: Thu Apr 19, 2007 8:10 pm
Here is a inside look at my thought process on the 2 items you have listed here.
First lets take the intake manifold, I would ask myself a few questions like why do I want to reduce the vibration absorption between my carb and Engine, I asked this long ago and its never answered, not a big deal I have answered this question myself, I have seen these intakes on sled engines their engines vibrate less and have softer Engine mounts, vibration isolation between the Engine and carb is important to reduce fuel frothing and upsetting the float.
I was told that manifold was made because a stock 350 manifold wont accept a 39mm carb so I took a old hard 350 manifold Hare gave me and proved him wrong so his wording was changed to it makes it easier to install a bigger carb. http://pilotodyssey.com/39mm350.htm maybe it is but as mention before it reduces isolation.
Why would I pay 100 bux for a manifold that does not match the reed cage? I can buy a new intake manifold from Honda that was engineered for my Engine for 25 bux ( part number 16210-VM0-000 INSULATOR, CARB $ 24.64 at service Honda)
If I am going to buy a new intake for 100 bux it will be matched perfectly to the reed cage I am going to use it wont require 'blending' before I use it.
Are you looking for something that does fit a bigger carb easier maybe one of these will fit a 350 too?
http://pilotodyssey.com/BTmanifold.htm Part number 16221-430-000 INSULATOR, CARB $52.61 at Service Honda.
I am not sold with the Vforce since day one, early on they were the latest buzz word and all the kids hyped them up all over the web, I have seen too many problems and the reeds are very short lived, carbon fiber does not maintain its tension as long as fiber glass, I know several Engine builders that have gone away from CF and back to fiberglass because of this, its not well known or often advertised simply because they build engines that are used in competition races like GNCC and AMA events, they don't really want the average Joe to know what really works. http://pilotodyssey.com/Vforce.htm http://pilotodyssey.com/cagemod.htm
I have only seen implied performance data nothing rock solid, no simple easy to understand no BS test that shows they are what they claim.
All my research on reed cages over the years has taught me that going from the worse reed cage to the best reed cage at best is about 3hp on a Engine like used in a Pilot or Odyssey, 3hp quoted gains I have found are always on a multi cylinder Engine also so divide the HP gains by 2 or 3, if you get a solid 3hp gain on your 12k RPM shifter go cart and your racing then by all means you better buy one, but IMO to shell out 150+ bux? for a reed cage for the occasional weekend romp is just a big waste of money, someone looking for scant gains a V force will provide is for the guy that changes his jetting 3-4 times a day as the days weather conditions change (temp and humidity) I think the money would be
better spent on spare parts or mods that give the biggest bang for the buck like a drive or driven clutch.
If your spare parts box is full and you have money to burn and you want to buy a Vforce please ensure the one your buying was design setup and tuned for your application, call and talk to Moto Tassinari yourself don't take a vendors word for anything, I say this because years ago someone contacted me from Moto Tassinari and told me the reed cage I posted failure pics of was not for a Pilot or Odyssey it was for a motorcycle implying the problems were caused by using the wrong application.
 Post subject: reeds
PostPosted: Fri Apr 20, 2007 5:43 pm
Thanks a lot Hoser, you summed that up very well for me. I definately see the 'big hype' with vforce. I did not realize that the carbon fiber will not last like fiberglass. I've changed my mind on those, Thankyou.
PostPosted: Sun May 13, 2007 11:02 am
BOYSEEN reeds have worked well for me on my 350's.Ed at Triple EEE installs them on all my motors and have never had any issues with them, the V-FORCE, and the others are good but as Hoser stated you must read into them for applications.And don't go and bother with the michigan mutt ideas-I still use the stock cage in some applications, I also never go over a 35 mm on my rides, I like the mid range and throttle response it gives me-I do mostly tight trail riding and the low end/mid range is my choice.
PostPosted: Tue Aug 14, 2007 8:21 am
Mutt still pedaling these I see
http://cgi.ebay.com/ebaymotors/Intake-m ... enameZWDVW
Check this out 16221-430-000 Service Honda $52.61
PostPosted: Tue Aug 14, 2007 6:05 pm
Stick with the fiberglass boyessen reeds. The throttle response may not be as crisp with the carbon fiber reeds but you will not have to worry about them. The carbon fiber reeds have been known to break off or "suck a reed". When I raced GNCC and harescrambles for kawasaki, fibergalass were the only reeds they would give me with their motors.
On the intake's, Brooks and I have tried several intake carb set ups on his 350. Air velocity is very important. If you put an intake and carb that is to big or overkill for the Engine then your bottom and midrange power will suffer. An example is with a CR 250 reed cage and stock carb we could roast the tires on asphalt. With a 38MM flat slide, removed the reed cage stuffer we were unable to spin the tires in the dirt, but it pulled hard on the top end. The stock carb will support heavy mods to the 350 Engine and you don't have to worry about your carb boots popping off because they don't fit 100%.
