It is currently Mon May 19, 2025 7:15 pm
PostPosted: Fri Feb 18, 2011 4:30 pm
is this the original piston out of a 350. need to know cause i might by this motor (( Internal Combustion Engine ? )) for a really good deal. but the guy is not sure what bore its on, so he sent me this pic, but i have never seen those numbers before.
PostPosted: Fri Feb 18, 2011 4:34 pm
heres a pic of the cylinder.
PostPosted: Fri Feb 18, 2011 5:14 pm
Here is the chart, since you cant measure the cylinder bore you have to assume that is the piston that was installed and it was the right piston, you also have to assume the cylinder needs bored at least once over.
I have found many cylinders that they had so much clearance between the piston and cylinder you actually had to go 2 bore sizes to 1. clean up the cylinder bore and 2. establish the correct piston to cylinder clearance.
Ask of ATV Racing has ever worked on it.
PostPosted: Fri Feb 18, 2011 5:39 pm
the Engine is located up here in canada so i doubt that atv racing has ever worked on it. does anyone recongnize the the numbers on the piston. i know it will have to be bored out for the new piston. but i don't want to buy a motor (( Internal Combustion Engine ? )) that is on it last bore.
PostPosted: Fri Feb 18, 2011 5:44 pm
The numbers on the piston are on the chart I attached to the last post here it is again.
PostPosted: Fri Feb 18, 2011 5:52 pm
sorry my bad hoser i was looking the numbers in blue. so this motor (( Internal Combustion Engine ? )) is still on its first bore then if i am reading it right.
do you guys think $100 for the entire motor (( Internal Combustion Engine ? )), stock reed, carb, air filter and box ,all wiring is there with CDI (Capacitor Discharge Ignition),coil,voltage reg ,full pipe ,both front and rear clutches ,fuel tank,fuel pump,is a good deal.
PostPosted: Fri Feb 18, 2011 6:02 pm
Yup buy it
PostPosted: Fri Feb 18, 2011 6:10 pm
thanks hoser....i just fired an email to the guy. will let you guys know how it goes
PostPosted: Sat Feb 19, 2011 1:19 am
lutrev wrote:
I go on Kiijijii :-)
that's where I found it. Still going to have some shipping to pay. Do u what company would the cheapest for shipping
PostPosted: Sun Feb 20, 2011 10:39 am
lutrev wrote:
just go canada post. fedex is good also. good score
i asked him to get a quote for C P, greyhound and someone like day ross
PostPosted: Sun Feb 20, 2011 11:53 am
Yup that's a great deal Image. I would recommend reading the following post: http://www.pilotodyssey.com/PO/viewtopic.php?f=2&t=4877&hilit=ups+motor (( Internal Combustion Engine ? ))" ! I cant tell you how may times I have bought fragile items over the internet and the shipper has no idea what kind of torture that package is going to endure between his house and mine. You will be wasting your money if you don't "pound it into the shippers head" that he must pack the Engine properly. I think the best way to pack it would be wrapped in a thick foam rubber or bubble wrap and then placed in a ice chest. UPS doesnt give a crap about anyones package except that it gets there on time. They don't care if it drops from a 3 foot tailgate or escalator belts, etc, etc. So good luck with the new parts!!
PostPosted: Sun Feb 20, 2011 7:06 pm
well i just had my feet kick out from under me. the guy i was buying from said that someone showed up to his place today and bought the motor (( Internal Combustion Engine ? )). so he sent me an email saying that it was easier to sell it to this other guy than to ship it to me. i am a little pissed off at him, but what can you do. with the amount of Engine troubles i had last year i would have been nice to have a Engine ready to drop in
PostPosted: Mon Feb 21, 2011 8:19 am
That sucks! that was a steal.
PostPosted: Mon Feb 21, 2011 10:33 am
well i sent him an email yesterday, and today he sent me the guys numbers. so i am going to call him and see if we can work out a deal. theres hope yet lol
PostPosted: Mon Feb 21, 2011 12:50 pm
You got roBbed!!! You snooze ya loose!
PostPosted: Mon Feb 21, 2011 4:16 pm
Definately wasn't snoozing been emailing for over a week with him
