It is currently Sun May 18, 2025 12:25 pm
PostPosted: Mon Apr 06, 2009 9:44 pm
Once I get my motor (( Internal Combustion Engine ? )) back together it looks like from reading post I need to do a leak down test,still not sure how to do it but once I get to that point I'm sure someone will help me out.My question is,I saw this at Harbor freight tools and was wondering if this would work for the test
PostPosted: Mon Apr 06, 2009 10:42 pm
here is a easy way to make one...
PostPosted: Mon Apr 06, 2009 10:58 pm
think u left something out,lol
PostPosted: Mon Apr 06, 2009 11:09 pm
I have Blond hair...
http://pilotodyssey.com/PO/viewtopi ... own+tester
PostPosted: Mon Apr 06, 2009 11:15 pm
well now I have a better idea how to hook it up,but he said it cost about 40 bucks to make,if that one from HF would work,its cheaper and i don't have to make it
heres a better look at it
http://www.harborfreight.com/cpi/ctaf/d ... mber=94190
PostPosted: Tue Apr 07, 2009 12:28 am
I think you will have to still buy the freeze plug for the exhaust. and something to plug the carb boot...
The box will be handy to keep it organized!!!
PostPosted: Tue Apr 07, 2009 9:11 am
I have the one on the right(red boxed one) and never used it. It is for 4 stroke car engines. 2 stroke engines you want to keep the pressure less than 10 lbs or run the risk of blowing out a seal.
I use a 15lb guage in my tester, just easier to read slow leaks. I put the guage on the crankcase to fuel pump line. I made an exhaust block off plate from scape metal and rubber gasket. You have to remove the header then install the plate with the 3 factory bolts. I put a air fill tip in a PVC pipe stopper. It works like a champ and costs less than $15 to make. Guage is the most expensive at $10. Hope that helps or at least gives you some ideas to try.
Gary
PostPosted: Tue Apr 07, 2009 11:18 am
Whatever you do, don't be a dummy like me and spend $70.00 greens on leakdown tester. I won't mention the name of the company I got it from but I had to modify it just to get the stupid thing to work and the gauge wasn't accurate..
PostPosted: Tue Apr 07, 2009 3:13 pm
I don't no what company your talking about,guy on ebay sells one for 69.95,is that who your talking about? Heck,I'll say it,chucklenuts at aftershot motorspurts Motorsports
PostPosted: Tue Apr 07, 2009 3:19 pm
yes that is the guy!!! LOL a f t e r s h o c k motorsspurt's is a shady charactor... It's sad you got took cruz1 and I bet $69.95 dollars he wouldn't stand behind his crap...
PostPosted: Wed Apr 08, 2009 12:33 pm
LOL. It didn't take long for you guys to figure it out.. The exhaust plug was too big to fit in the spigot so I had to shave off about 50% of the rubber so it would work. Although the plug didn't fit and the gauge is not accurate, the thing still does the job but absolutely not worth the $70 smackers...
PostPosted: Sun Apr 19, 2009 9:12 am
does the cylinder need to be on to do a test?
PostPosted: Sun Apr 19, 2009 9:31 am
Yes, ideally you want the whole Engine assembled as its going to be run, you cap off the exhaust and the intake side preferably by just removing the carb and inserting a plug that way your checking the intake manifold too, you also want to remove the pulse tube that goes to the fuel pump and plug.
I use the pulse line to hook up my home made tester pics seen here http://pilotodyssey.com/rebuild1.htm
Think I spent about 10 bux on mine.
You want to air it up to about 10 psi see how long it holds.
I air my portable air tank up to 10 psi so I CANT over pressurize my Engine by accident and blow out the seals. :shock:
PostPosted: Sun Apr 19, 2009 11:59 am
thanks,it made sense to me that it would be but i saw a pic in another thread of a leak down tester installed on Engine and cylinder was off so it got me wondering
PostPosted: Sat Apr 25, 2009 3:46 pm
okay,bought parts for tester but not sure what that fitting is where arrow is,do you have better pic with cap off?
thanks
PostPosted: Sat Apr 25, 2009 3:57 pm
thanks
that's just a valve stem so you can add air found them in the section where they keep air compressor stuff.
PostPosted: Sat Apr 25, 2009 5:42 pm
thanks
that's what I thought but i couldnt find any like that,guess i'll try another place
PostPosted: Sat Apr 25, 2009 6:15 pm
redskinman wrote:
thanks
Try tractor supply!!!
PostPosted: Tue Apr 28, 2009 2:02 pm
thanks
I can not find one in person or online,where did you get yours?
PostPosted: Tue Apr 28, 2009 6:32 pm
well I found a valve stem at tractor supply but its 1/8 od,not 1/4 and i cant find any adapters,so i went back to the drawing board,harbor freight had their fuel injection tester on sale for 8.99,so with parts from it i made mine,just going to hook up directly to air compressor hose with only 10 lbs of air in compressor tank.Going to just use 2 flat pieces of aluminum to block of ports.Do you think this will work or will the air slowly leak back up hose from Engine into compressor tank?
PostPosted: Tue Apr 28, 2009 6:42 pm
redskinman wrote:
thanks
I got everything for my kit at Farm & Fleet
PostPosted: Tue Apr 28, 2009 7:06 pm
never heard of it,do you think my setup will work?
also Hoser check your pm's
thanks
PostPosted: Tue Apr 28, 2009 7:11 pm
thanks
Your setup should work but the key thing to worry about is controlling the air pressure, with the valve stem fitting I take my air chuck and just pop it on and off fast to get it to 10 psi, their is only 10-15 psi in my air tank when do this so I cant over pressurize the Engine and blow the seals :shock:
You also need to disconnect from the air source so the only pressure your reading is whats inside the Engine, maybe a ball valve between the air tank and your kit?
PostPosted: Tue Apr 28, 2009 7:23 pm
thanks
well there a ball valves on compressor hooked to hose and hose is hooked directly to my setup,so i can have about 10 psi in compressor tank,open ball valve,fill Engine with air,then shut off ball valve,sounds like we have a winner!
