I decided to make a leakdown tester using the pulse/vacuum line to pressurize the
motor ((
Internal Combustion Engine ? )).
The rubber boot intake for the carb measures in at 1.45". I used a 1 3/8" (1.375") expanding freeze plug for this plug.
The exhaust plug (For a DG Pipe) measures in at 1.78". I used a 1 3/4" (1.75") expanding freeze plug for this plug.
The freeze plugs can be found at any auto parts store.
Attached are pictures of my setup.
Search words added by hoser
pressure tester
pressure test
leak down test
leakdown test
leak test
