It is currently Sat May 17, 2025 10:19 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3  Next
 Post subject: Akpilots Wildcat build
PostPosted: Mon Apr 15, 2013 8:44 pm
Purchased a Wildcat in Feb of 2012, number #35. Picked up in March and knew it would not stay stock long just loading it up in the parking lot. I decited to ship off clutches before I even rode the thing. So while waiting on clutches I build these:
Ak
File comment: The front bumper needed somthing?
File comment: So I added Bling......just cus
File comment: Made a rear bumper
File comment: Then took a '99 GSXR pipe from the 1/2 off bin, cut front off and welded to fit Wildcat.
PostPosted: Mon Apr 15, 2013 8:54 pm
Second or third ride my daughter's friend decited the Wildcat was too slow after the Nytro Pilot so he decited to go out of view and wring her out......well he rolled it doing 6500 dollars damage. In Alaska if you loan out your car, trailer, wildcat or what ever you also loan out your insurance....So yea my insurance took a hit. I ended up cutting and welding original bottom frame and built my own upper cage. Puchased new doors, fenders ect.
Ak
File comment: Building the new cage
File comment: A ride out at big lake just before Tyler and I decited to put in the Apex
PostPosted: Mon Apr 15, 2013 9:07 pm
Since the Wildcat Engine and trans are one unit I needed a transmission. I'm going with a Polaris 900 XP trans. Looked on RZR sites and they have good track record of Apex's in both RZR S' s and 900's so that's what I'm doing.
File comment: Cut frame just behind the seats and just below the hip rail. Made a jig table holding original subframe
File comment: XP 900 Trans is wider so I'm making the suspension mounts wider - 3/4" on each side
File comment: Bottom of new subframe with new lower mounts
File comment: XP trans with upper suspension mounts.
File comment: Setting in the motor (( Internal Combustion Engine ? )). I originally purchased this Apex before the Nytro Pilot build, but the motor (( Internal Combustion Engine ? )) was too wide for that frame so I made it into a sled and rode it for the past 4 to 5 seasons.....LOVE this motor (( Internal Combustion Engine ? )) but it was always destin for a buggy.
File comment: All wedged in.
PostPosted: Mon Apr 15, 2013 9:16 pm
continuing on.......
File comment: Header will be FUN!!! Yea that is 1.5" from #1 cylinder to trans.
File comment: Making rear mounts
File comment: Front mounts, which I changed....
File comment: Basic sub frame
File comment: Test fitting to see if she fits, front lower mounts
File comment: This is how the rear mounts up to the hip rail
PostPosted: Mon Apr 15, 2013 9:26 pm
More
File comment: She fits, I will be pushing out the trailing arms to the outside of OEM mounts and make new outer mount
File comment: OEM radiator fits, so does the rear bed.
File comment: Only the right rear radiator mounts need to be relocated.
File comment: Start of the header, 4 each 1.5" stainless tubes on the notcher
File comment: Each tube gets two cuts
File comment: 4 tubes to make up collector
PostPosted: Mon Apr 15, 2013 9:48 pm
Again more.....
The exhaust has expansion/vibration joints but I also want the header to be rubber mounted that's why I'm looking for the Pilot Engine/trans mounts they work great.
Ak
File comment: Start with furthest away, made this tube the same length as the stock header. As you can see I used header donuts to move #1 & #2 cylinders up above the trans.
File comment: #3 cylinder, I'm using masking tape to hold together as I build.
File comment: Now the fun one.
File comment: Another shot of #1
File comment: Finally #2 cylinder. The tubes are within 3/8" of each other which was tough enough for me! But so far this has been the best part of the build thus far, the hardest usually is.
PostPosted: Mon Apr 15, 2013 10:05 pm
My NEMESIS the Gas/Oil tank combo.
File comment: Start of the Sump
File comment: OEM fuel pump in sump
File comment: The sump is large because the pump on the right side and the 4X4 shaft on the left side
File comment: Main tank taking shape
File comment: Filling in the little voids to get as large of a tank as I could. When I started I was thinking I had plenty of room but it's going quick
File comment: Basic upper tank, hugging the plastics as best I could. Oil resivior will be on the left.
PostPosted: Mon Apr 15, 2013 10:15 pm
More tank
File comment: Fuel sending unit mount
File comment: Fuel pump mount
File comment: 1/4" tabs weld to gas tank and oil tank, then a weld to hold the oil tank onto the gas tank. In the 1/2" void will be fiberglass heat sheild just like I did on the Nytro Pilot.
File comment: Oil tank taking shape
File comment: Oil tank sump
File comment: Inner baffeling for oil tank. The tube is the return air to the crank case. This will be MUCH easier than the Nytro as the Apex case is vented not by this tube, so if oil does make it back to the case no big deal. On the Nytro this tube goes to the air box, and yea I fought it!
PostPosted: Mon Apr 15, 2013 10:28 pm
This is where I'm at now, man wish the build took as long as this posting...... I'll update this with my thread on Wildcat.net, this is a bit condensed but probably better for viewing.
Still need to weld the top of the oil tank and it is done, build the back and top of the gas tank, but probably going to start wiring as the tank will mount most of the electronics, so I need to know where they go. Its definately nice to have a removable subframe! no bending over and climbing around a Pilot frame :-) . Can't take credit for the subframe that goes to Proto die, always liked how everything goes in and out easily. The only thing I'll need to disconnect is the coolant along with the wiring.
Ak
File comment: Dipstick! No not me the oil dipstick
File comment: Gas filler taking shape. This tank is going quick compaired to my other builds. No foam 3d model like the Nytro. I'm just wingin' it with lots of construction paper.
PostPosted: Mon Apr 15, 2013 10:50 pm
you got some mad fab skill..keep up the good work
PostPosted: Mon Apr 15, 2013 11:49 pm
Nice work. You are obviously skilled at fabin.
PostPosted: Mon Apr 15, 2013 11:51 pm
I do have a question though. Why would you use a holesaw and not a milling bit to cope pipes??
Milling bit would last longer wouldn't it?
PostPosted: Tue Apr 16, 2013 2:29 am
when that 150 hp ain't enough you can turbo it :-)
PostPosted: Tue Apr 16, 2013 5:10 am
XP trans has a chain drive for reverse and they are breaking :shock:
Project looks good cant wait to see it finished looks like a lot of work, should be a really fun machine.
PostPosted: Tue Apr 16, 2013 9:26 am
Nice job on the fuel tank! I was wondering where the AKpilot got that fancy tank. Great work.
PostPosted: Tue Apr 16, 2013 10:22 am
Youve got some skills,great job
Daughters friend sounds like a douche
PostPosted: Tue Apr 16, 2013 1:31 pm
Thanks guys, Yea my wife still does not know why I do this but to me it is relaxin', I like building more than riding :shock: Mostly because here in Alaska we don't have dunes, only snow and mud. Hence why I got a 4X4 buggy.
Hoser - yea I heard of the reverse chain issues, don't plan on muddin' this just go out to river beds and old logging roads. A couple of other WC owners want me to go with them but where they go it just destroys them, not my cup of tea.
Canadian Oddy - milling bit would be better, but I only burned up one hole saw bit making the header. I don't use the notcher much, with cromolly I just bandsaw/grind notch, it does however work great on Aluminum. Made a couple of roof cages for the boss' Argo's and it worked great, also the Wildcat bumpers.
BS - Yea, I need to either make a smaller gas tank or it's getting boosted. :-) On the Nytro I put the airbox on top of the tank but this tank would be pretty small, right now I'm looking at a 10+ gallon tank but with airbox....much smaller. A couple of my sled heads buddy's are pushing for it, we'll see. Trany is my big hang up right now.
Ak
PostPosted: Tue Apr 16, 2013 8:25 pm
Each and every thread and or project you do I am glued to the thread. You skills are unmatched, your projects are bar none informative, cutting edge and always crafted to perfection with safety, clean lines, superb welds and items fabricated with ungodly craftsmanship.
Very nice, please keep us updated! :-)
PostPosted: Wed Apr 17, 2013 2:06 am
Mudbogger,
Your making me blush :-) ....I appreciate it. I too enjoy reading a thread that gets into the How to, and pics, I learn as well. BTW if anyone has questions on how I did something just ask.
Ak
PostPosted: Wed Apr 17, 2013 6:18 am
Yeah,I have a question! :shock:
What made you want to be the DastardlyDuneBuggyDiablo huh???Image
How many souls do you own now(notice own/now similarity?),how do you sleep at nights.............................you DO sleep? Image
PostPosted: Thu Apr 18, 2013 11:37 am
I gotta wonder, why did you even buy a WC in the first place? With your skills, why didnt you just buy the components you need and build your own UTV?
PostPosted: Mon Apr 22, 2013 1:23 am
Nick
Yea that probably, but this one was not suposed to be modified.....or well that's what I told my wife.
File comment: Setting up the fuel gauge. sending unit just misses baffle. I straightened out float wire and added all I could, would have liked to have float at bottom.
File comment: bottom sump is just a hair over 1 gallon. I'll have 3 gallons once gauge hits empty. Tank is 12 gallons
File comment: Start of wiring, stripped and ready to start cutting
File comment: Been around Pilots too long, mimiking the metal wiring tabs.
File comment: Mounting all the electrical on the tank. Yea the tank is mounted with Honda Engine mounts. Works great as they are mounted in single shear, that way subframe can move away.
PostPosted: Mon Apr 22, 2013 4:03 pm
Akpilot wrote:
Nick
It's just a slight modification :shock:
PostPosted: Wed Apr 24, 2013 3:01 am
the apex's are great engines.
there basically an R1 Engine without the trans
the tig welding looks great
what brand/model welder you using ?
PostPosted: Wed Apr 24, 2013 9:23 pm
BS
Started out with a Lincoln 175 Pro but the Fl800 tank was too big, could not get enough heat on it so I purchased a Lincoln 275.
Ak
