2010 RZR 800 barn find.... http://www.pilotodyssey.com/PO/viewtopic.php?f=104&t=16778 |
Page 4 of 4 |
Author: | FloridaEdd [ Fri Jul 28, 2017 1:05 pm ] |
Post subject: | Re: 2010 RZR 800 barn find.... |
Caution. Owning a tractor will make u soft. All that heavy stuff I used to muscle around kept me in shape and once I had a tractor I got soft. |
Author: | DMoneyAllstar [ Mon Jul 31, 2017 11:25 am ] | ||
Post subject: | Re: 2010 RZR 800 barn find.... | ||
hoser wrote: DMoneyAllstar wrote: And I finally got a tractor...and still got to keep my RZR! $2800 for a very clean fully functional 1984 Ford 1210 4wd diesel with 768B loader (lifts 1/2-ton), 3pt, pto, etc. Bought it from a pastor who's church has owned it for a decade or so. Its lived a good life and will live even easier in my barn. Where was the tractor made? Japan with the Shibaura 3-cyl diesel. Ford just slappity-slapped their name on it. Shibaura built a bunch of tractors for Ford-NewHolland. In other news, I took the RZR out for some wheelin' this weekend around my yard and rural neighborhood with -0- issues. Except I realized I forgot to install one spacer bushing in my steering wheel. Already corrected. No issues with the XP1000 front diff hooking up. I did learn that when driving through a recently harvested wheat field at 40-50mph...without the underbelly skid plate on...the chaff and debris from the field will get sucked up into the cab between seat-back and clutch cover and try to suffocate you, lol. Not cool. Thought my sister and I were going to die coughing. Also learned one of my old/stock front diff's hubs were cracked. I was going to sell the hubs to someone but found a massive crack when i cleaned them up. That front diff was 100% bombed! Glad I completely replaced it.
Author: | DMoneyAllstar [ Thu Aug 03, 2017 9:34 am ] |
FloridaEdd wrote: Caution. Owning a tractor will make u soft. All that heavy stuff I used to muscle around kept me in shape and once I had a tractor I got soft. Heard that! Amazing how many times I've already used the loader for something. Takes 3x longer, but I just get to sit there on my azz! And I've converted all kinds of heavy stuff from sitting on the ground to sitting on a pallet. Need to make a concrete counterweight though. Things got a little too tippy a couple times (whle I was sitting on my azz though!). |
Author: | canadian oddy [ Thu Aug 03, 2017 1:09 pm ] |
DMoneyAllstar wrote: FloridaEdd wrote: Caution. Owning a tractor will make u soft. All that heavy stuff I used to muscle around kept me in shape and once I had a tractor I got soft. Heard that! Amazing how many times I've already used the loader for something. Takes 3x longer, but I just get to sit there on my azz! And I've converted all kinds of heavy stuff from sitting on the ground to sitting on a pallet. Need to make a concrete counterweight though. Things got a little too tippy a couple times (whle I was sitting on my azz though!). WATCH IT !! If you need a counter weight your stressing that machine. The factory would have installed a counter weight if it was engineered for one. It also has no roll hoop. Your asking for trouble. |
Author: | go oddy [ Thu Aug 03, 2017 2:26 pm ] |
canadian oddy wrote: DMoneyAllstar wrote: FloridaEdd wrote: Caution. Owning a tractor will make u soft. All that heavy stuff I used to muscle around kept me in shape and once I had a tractor I got soft. Heard that! Amazing how many times I've already used the loader for something. Takes 3x longer, but I just get to sit there on my azz! And I've converted all kinds of heavy stuff from sitting on the ground to sitting on a pallet. Need to make a concrete counterweight though. Things got a little too tippy a couple times (whle I was sitting on my azz though!). WATCH IT !! If you need a counter weight your stressing that machine. The factory would have installed a counter weight if it was engineered for one. It also has no roll hoop. Your asking for trouble. Not always... many machines are engineered for a counter weight or backhoe setup... I've used machines with filled tires and a hoe and still felt light in the arse on uneven terrain |
Author: | DMoneyAllstar [ Thu Aug 03, 2017 2:51 pm ] |
canadian oddy wrote: DMoneyAllstar wrote: FloridaEdd wrote: Caution. Owning a tractor will make u soft. All that heavy stuff I used to muscle around kept me in shape and once I had a tractor I got soft. Heard that! Amazing how many times I've already used the loader for something. Takes 3x longer, but I just get to sit there on my azz! And I've converted all kinds of heavy stuff from sitting on the ground to sitting on a pallet. Need to make a concrete counterweight though. Things got a little too tippy a couple times (whle I was sitting on my azz though!). WATCH IT !! If you need a counter weight your stressing that machine. The factory would have installed a counter weight if it was engineered for one. It also has no roll hoop. Your asking for trouble. No worries. It has ROPS, and the 3pt lift is rated for 881 lbs. Rear tires are tubed ag tires and fronts are foam filled ag tires. The factory spec'd it out for holding a backhoe, too. I'm gonna' make a 500# concrete weight I can pick-up with my carry-all (18" cube of concrete). Most of the 4' pto tillers for it also weigh 500-700#, but I'm not ready to fork out $1500 for a tiller just yet. Built like a tank. 1980's they built a lot of nice stuff. Stuff made by brands like Briggs and Craftsman were awesome then. New stuff is all garbage unless you want to pay 2x. |
Author: | FloridaEdd [ Thu Aug 03, 2017 7:48 pm ] |
For what it's worth roll bar up seat belt on. Roll bar down seat belt off. Roll bar down and seat belt on will crush u in a roll over. My rear tires are filled with water and I made a counter weight that I fill with water as needed. My want to incorporate a bracket for ur 3pt to move a trailer around and makes a great place to mount what ever counter weight u come up with. An auger is a great attachment I use mine all the time. You will find urself coming up with uses just to drive it around. As a added note counter weights are not added at the factory because not all tractors have loaders attached and different loaders handle different weights so the amount of counter weight needed would vary with the loader you select. Counter weights and water filled tires are widely used. |
Author: | DMoneyAllstar [ Fri Aug 04, 2017 10:18 am ] |
FloridaEdd wrote: For what it's worth roll bar up seat belt on. Roll bar down seat belt off. Roll bar down and seat belt on will crush u in a roll over. Amen to that, for sure! This weekend I'm gonna make a set of (4) 18x18x6" concrete slabs with steel mesh...1 slab with twin 18" steel pipes sticking up and set on a pair of 24" 4x6 wood rails, and 3 with matching holes. Then I can vary between 150-300-450-600#. Simple wood forms. Will cost all of about $45, lol. Need to get this together so I can go pluck my Rotax470 swap FL350 chassis out of my dad's barn and get it back in the shop. |
Page 4 of 4 | All times are UTC - 5 hours [ DST ] |
