It is currently Sat May 17, 2025 7:06 pm
PostPosted: Sun Jan 22, 2012 6:11 pm
Well here it is all done with welding fixture
First one off turned out good need to tune it in a little
The bumper has the same top tube as the fl350 and grab Bar ( not a tow bar ) :)
there are two down brackets made out of 12ga steel bent on a 90 for strength
the flange can be drilled for a skid plate of your making
it has two hole for the stock Honda plastic and will need 1" spacers and new lower bolts
See pic's
Thanks SpeedChaser
P.S. I have not worked up a price yet but will be soon
File comment: making of weld fixture
File comment: all bolted up ready to weld a bumper
File comment: side view
File comment: close up of lower tab
File comment: other side
Here is some pic's after welding up first bumper
fit was not to bad fixture need a little fine tuning
thanks for looking
Speed
File comment: after first bumper off the fixture
not bad need to pull around to get all the bolts in but I'm working with a bent up front end not to perfect but close
File comment: I'm standing on a five gal pale :)
File comment: lower tab with 1" spacer added for plastic skid
File comment: Note see that I'm using the lower tube for support On the bracket
lower tap holds this in place
File comment: bumper sits about 6-1/2" out forward from top frame tube
File comment: last pic of the day
PostPosted: Sun Jan 22, 2012 6:59 pm
Looks great speed. Is there going to be a skid plate option for those of us who no longer have the plastic skid, or the plastic skid has been destoyed?
PostPosted: Sun Jan 22, 2012 7:15 pm
speed
PostPosted: Sun Jan 22, 2012 7:54 pm
Guess i shoulda read closer. haha sorry. But it looks good. If they are priced like your 350 bumpers i will probably pick one up!
PostPosted: Sun Jan 22, 2012 7:58 pm
Very nice.I like it flat as opposed to the earlier pic where the ends were turned up.
Nice fixture work too,that takes some time to figure out.
PostPosted: Mon Jan 23, 2012 9:23 pm
Very nice indeed, another job well done sir!
PostPosted: Thu Jan 26, 2012 1:47 pm
looks awesome speed........
PostPosted: Fri Feb 03, 2012 10:51 am
Hello I have the fixture all tuned in
will have 8 front bumpers ready to go out next week starting 2-7-12
The bumper will be bare steel full welded with grab bar No bolts or spacers will be supplied
spacers will be needed if you are running the stock plastic skid plate the spacer is 1" long 3/4" od x 11/32 id you will need two
I can make them but have not got around to it yet
with that being said the bumpers will be priced at
$150 with free shipping with in the USA money order or check
$158 with free shipping with in the USA PayPal
Thanks Speed
P.S.
The Rear Honda line Bumpers are going to be bent up on a cnc tube bender at a company that I do work for this weekend will post in forum with updates thanks
PostPosted: Fri Feb 03, 2012 12:14 pm
Looks good.
don't forget the optional flag tab as required by MI at the dunes, I know this has been requested in the past by Pilot Odyssey owners.
PostPosted: Mon Apr 30, 2012 6:40 pm
On sale now http://www.ebay.com/sch/speedshop505/m. ... 4340.l2562
