It is currently Tue May 13, 2025 9:36 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: The rebuilding
PostPosted: Tue Mar 03, 2015 1:18 pm
Nice stuff there. What pressure on the rad cap? Yes I like the bling.
More please.
PostPosted: Tue Mar 03, 2015 6:42 pm
the cap that is on it is what came with it I don't know what the PSI is yet I will look when I get home. what should the pressure be on a 670 Rotax Engine
PostPosted: Tue Mar 03, 2015 6:44 pm
Haha sorry about the pronunciation I am doing voice texting on my phone
PostPosted: Tue Mar 03, 2015 6:50 pm
All the 670 sleds I have parted out use a 1.1 bar / 16 psi cap
PostPosted: Tue Mar 03, 2015 7:02 pm
that works most cars run 16 or 17 p s i so I should be good
PostPosted: Tue Mar 03, 2015 8:47 pm
Yup. My civic rad had a 16psi cap.
PostPosted: Wed Jun 03, 2015 6:24 am
C'mon Chris,pull ya finger out mate!...AND THEN??? :-)
PostPosted: Wed Jun 03, 2015 6:34 am
Progress?
PostPosted: Fri Jun 05, 2015 12:21 am
None yet. been working alot.. Some updates on my 670 build. I went with the 657x intake and carbs. Found two air leaks on the bottom case bolts, never seen that before. ill get some pics
PostPosted: Sat Jun 06, 2015 9:07 pm
ok quick update I'm back on the Engine. found all of my air leaks got them all fixed and the Engine is holding pressure. I got rid of the 583 carburetors and opted to go with the 670 X Intake setup and carburetors. notice these carburetors are turned sideways so you can access the Jets without taking the carburetors apart. plus I'll get a little more performance out of them and they should be jetted just right for the 670
PostPosted: Mon Jun 08, 2015 9:46 am
i like the carbs. how did you do the pressure test? got any pics of the tooling or a procedure link?
