PilotOdyssey.com
The rebuilding
http://www.pilotodyssey.com/PO/viewtopic.php?f=123&t=15343
Page 3 of 3
Author:  adnoh [ Tue Mar 03, 2015 1:18 pm ]
Post subject:  Re: The rebuilding
Nice stuff there. What pressure on the rad cap? Yes I like the bling.
More please.
Author:  halorising [ Tue Mar 03, 2015 6:42 pm ]
the cap that is on it is what came with it I don't know what the PSI is yet I will look when I get home. what should the pressure be on a 670 Rotax Engine
Author:  halorising [ Tue Mar 03, 2015 6:44 pm ]
Haha sorry about the pronunciation I am doing voice texting on my phone
Author:  nitrosport_5 [ Tue Mar 03, 2015 6:50 pm ]
All the 670 sleds I have parted out use a 1.1 bar / 16 psi cap
Author:  halorising [ Tue Mar 03, 2015 7:02 pm ]
that works most cars run 16 or 17 p s i so I should be good
Author:  nitrosport_5 [ Tue Mar 03, 2015 8:47 pm ]
Yup. My civic rad had a 16psi cap.
Author:  bugeye59 [ Wed Jun 03, 2015 6:24 am ]
C'mon Chris,pull ya finger out mate!...AND THEN??? :-)
Author:  hoser [ Wed Jun 03, 2015 6:34 am ]
Progress?
Author:  halorising [ Fri Jun 05, 2015 12:21 am ]
None yet. been working alot.. Some updates on my 670 build. I went with the 657x intake and carbs. Found two air leaks on the bottom case bolts, never seen that before. ill get some pics
Author:  halorising [ Sat Jun 06, 2015 9:07 pm ]
ok quick update I'm back on the Engine. found all of my air leaks got them all fixed and the Engine is holding pressure. I got rid of the 583 carburetors and opted to go with the 670 X Intake setup and carburetors. notice these carburetors are turned sideways so you can access the Jets without taking the carburetors apart. plus I'll get a little more performance out of them and they should be jetted just right for the 670
Author:  ChrisV [ Mon Jun 08, 2015 9:46 am ]
i like the carbs. how did you do the pressure test? got any pics of the tooling or a procedure link?
Page 3 of 3 All times are UTC - 5 hours [ DST ]
https://www.phpbb.com/
