It is currently Thu May 15, 2025 4:28 am
 Post subject: Cooler Rack for Pilot
PostPosted: Wed May 15, 2013 11:46 am
I ran into these cooler racks for Pilots on craigslist.
http://losangeles.craigslist.org/lgb/fo ... 95079.html
Is this anyone on the board making these?
PostPosted: Wed May 15, 2013 11:48 am
Here's a pic from the listing.
PostPosted: Wed May 15, 2013 11:52 am
My Pilot came with one when I bought it,I didnt realize till later it was put on there,I thought all Pilots came with them,lol
Mine doesnt look like this one though
PostPosted: Wed May 15, 2013 11:56 am
I like the way it uses the cage bolts to suspend it. I can't us it as I have my pre filters in the way.
PostPosted: Wed May 15, 2013 12:06 pm
I was thinking about one for the Wife's Ody.
Anyone know if the width of the top of the cage is close between the pilot and the ody?
How about the upper frame bolt spacing?
PostPosted: Wed May 15, 2013 12:43 pm
This is mine,the small igloo cooler fits it perfectly
PostPosted: Wed May 15, 2013 3:56 pm
That is a pretty nice setup, would you use longer frame bolts and nut it?
PostPosted: Wed May 15, 2013 4:06 pm
All depending on how thick the side mounts are you may be able to use the factory hardware. I have an overflow bottle bracket mounted to Ridindirty's Ody and just used the factory roll cage hardware. The thickness of the bracket is probably around .030". Anything more than that and you would need a longer socket head cap screw.
PostPosted: Wed May 15, 2013 4:12 pm
I think redskinman's painted nuts threw me off :-) Not saying that's why he is called redskinman or anything.
I was thinking that the nuts were welded on the the cage but now as I recall they aren't.
PostPosted: Wed May 15, 2013 4:19 pm
I was bidding on one similar to this and lost.
PostPosted: Thu May 16, 2013 12:21 pm
those would be good for carrying extra fuel
PostPosted: Thu May 16, 2013 12:25 pm
Anyone know if the bolt spacing for the Pilot's down tubes are the same for an FL350 Odyssey?
