Pre filter http://www.pilotodyssey.com/PO/viewtopic.php?f=2&t=18518 |
Page 1 of 1 |
Author: | PilotJunkie_87 [ Mon Apr 22, 2019 1:57 pm ] | ||
Post subject: | Pre filter | ||
Are these worth getting for riding in the sand? I had a problem last time that my One machine blew up from sucking in sand. Should this mitigate that problem?
Author: | rmesser [ Mon Apr 22, 2019 2:52 pm ] | ||||
Post subject: | Re: Pre filter | ||||
This is what I did. I also recommend pantyhose to cover the prefilters. cheap and disposable.
Author: | Kuma [ Mon Apr 22, 2019 3:45 pm ] |
I do not recommend K&N fabric filters, if you do a search you see that many others are in agreement, use a foam filter with sticky oil like FFT, I then use filter skins, they get dirty but catch 80% of the sand before it gets to the foam filter, you can change those out if needed, and finally do some sort of pre-filter as shown, for mine I did use a fabric filter, I didn't even bother to oil that one, mostly just used to keep out the bigger stuff and knock it down before getting to the inside filter. Those pre-filter socks I'm sure help but I have found they would let the fine stuff in and not let it out. |
Author: | PilotJunkie_87 [ Mon Apr 22, 2019 4:55 pm ] |
Where would I buy the filter skins? |
Author: | redskinman [ Mon Apr 22, 2019 5:53 pm ] |
Yeah what Kuma and rmesser said,K&N sucks for keeping out sand.I think most people run the 2 stage uni filter with the sticky oil,and some run the prefilter like Kuma said.The K&N would probably be ok just to use as your prefilter but that's about it. https://www.ebay.com/itm/UNI-Air-Filter ... SwvFpbfjvM |
Author: | PilotJunkie_87 [ Mon Apr 22, 2019 7:11 pm ] |
I have a oiled foam filter now, is there a cover I can buy or a filter net I can buy as an added layer of protection. |
Author: | redskinman [ Mon Apr 22, 2019 9:32 pm ] |
PilotJunkie_87 wrote: I have a oiled foam filter now, is there a cover I can buy or a filter net I can buy as an added layer of protection. Are you running an airbox? If so you shouldn't need an outerwear.I know they make these but I don't know if unifilters are designed for these to be worn over them. https://www.denniskirk.com/outerwears/u ... gI6SvD_BwE |
Author: | PilotJunkie_87 [ Tue Apr 23, 2019 12:29 am ] |
Yes my set up is 100% stock |
Author: | Kuma [ Tue Apr 23, 2019 11:03 am ] |
I would still use a filter skin on the foam filter. it's funny that the Spammer located the post about the K&N Filters that hoser started :) |
Author: | redskinman [ Tue Apr 23, 2019 4:01 pm ] |
Kuma wrote: I would still use a filter skin on the foam filter. it's funny that the Spammer located the post about the K&N Filters that hoser started :) What's a filter skin? Like the outerwear I posted link to? |
Author: | Kuma [ Wed Apr 24, 2019 4:08 pm ] |
http://www.pcracingusa.com/FilterSkins_c_18.html I usually oil them with K&N fabric filter oil, they do get dirty, but you can easily swap them out or even put it off knock the sand off and reinstall. I desert racing friend of mine showed them to me, there is a way you can stack them in layers and have a string coming out of the airbox and during a race you can pull off the dirty top layer, I've never done that myself |
Author: | redskinman [ Wed Apr 24, 2019 6:46 pm ] |
Kuma wrote: http://www.pcracingusa.com/FilterSkins_c_18.html I usually oil them with K&N fabric filter oil, they do get dirty, but you can easily swap them out or even put it off knock the sand off and reinstall. I desert racing friend of mine showed them to me, there is a way you can stack them in layers and have a string coming out of the airbox and during a race you can pull off the dirty top layer, I've never done that myself Well you learn something new everyday I have never seen or heard of those before |
