It is currently Thu Apr 18, 2024 11:33 pm
 Post subject: Frozen choke
PostPosted: Thu Mar 16, 2017 8:23 am
Has anyone ever had their choke cable freeze during a ride? So I stared my pilot in my garage, drove it on the trailer and went to start it again once I got to my riding spot and the choke was stuck so I stuck it in our garage by the heater and it started working again.
Once I got home I took the end of the choke apart and sprayed penetrating oil down in the cable and put a little bit of synthetic grease on the cable. I also noticed that little rubber piece and the little plastic nut on the end of the choked seemed to have a little water in the joint. So I put a little black silicone on the joint between the two, I also put a very small amount at the top of the rubber piece where the cable goes in and a small amount on the choke holder nut threads.
Any other suggestions on what to do?
 Post subject: Re: Frozen choke
PostPosted: Thu Mar 16, 2017 9:01 am
Could you cover the joint with heat shrinkable tubing?
I have had damaged cables, where the plastic housing was worn off and I sealed it up using shrink tube.
PostPosted: Thu Mar 16, 2017 9:05 am
I'll do that if the silicon doesn't work. I'm half tempted to replaced the cable, but once the pilots sitting in the garage warmed up it works perfect, doesn't stick at all. I believe I replaced it like 2-3years ago but haven't ran them much since.
PostPosted: Thu Mar 16, 2017 3:36 pm
if you have water in the cable, you may want to try flushing it out with some wd40, then use some cable lube on it, motion pro makes a tool that hooks to the cable for lubing the cable.
Registered users: Bing [Bot], chorizofingers, Garemie, Google [Bot], Lanix
