It is currently Fri Apr 26, 2024 9:21 am
PostPosted: Tue May 23, 2017 3:43 pm
Hello all,
I have a Dodge 2001 Caravan SE, with the 3.3L Engine, which can use E85 or unleaded fuel.......I did a smoke test due to an emission code I was getting. I did have smoke coming out from the gas cap, as it did not seem to be sealing.
My question is, is there a difference in gas caps designed for the different fuels? I have tried searching online, and checked different auto parts stores. Some have different caps for the different fuels (yellow vs black) and other stores list the same cap for both fuels.......I am also checking with the dealership, but so far cannot find a definitive answer.
I did try two different brands of caps (Carquest and Stant) but both leaked......(smoke test both times)......
Any advice would be appreciated. Thanks
PostPosted: Tue May 23, 2017 3:59 pm
Lonerider wrote:
Hello all,
I can't really say for sure but don't you need to vent a fuel tank ??
It would create a vacuum if you didn't.
Not sure how fuel systems in vehicles do it today, but if it is a vented system then you're gona get a positive for a leak somewhere.
PostPosted: Tue May 23, 2017 4:47 pm
canadian oddy wrote:
Lonerider wrote:
Hello all,
That is true, but I believe it is to be vented thru the emissions (evap) system. All the videos and information I have gotten is that the first thing you do is check your gas cap for a good seal. Kind of like when you put gas in your vehicle, if you do not tighten the gas cap good, it will give you an error code. The codes are P0442 and P0455.
PostPosted: Tue May 23, 2017 7:23 pm
Hey long time no talk I hope you and the family has been well.
I would contact scpilot66 and ask him memberlist.php?mode=viewprofile&u=1518 tell him hoser sent you :-)
PostPosted: Tue May 23, 2017 7:50 pm
Hi Hoser,
Family is well, thank you...hope your family is the same....
Remember those two midgets that went to pick up the 350 with us? They are both graduating from high school on Friday.
Man, time sure does fly by........
PostPosted: Tue May 23, 2017 8:23 pm
Lonerider wrote:
Hi Hoser,
Wow time does fly Congratulations to both I wish them well and success in the future :-)
PostPosted: Tue May 23, 2017 11:41 pm
Thanks!
