It is currently Sun May 18, 2025 12:38 am
PostPosted: Sat Jun 07, 2008 4:58 pm
SHADOW sent me his Pilot cylinder, I forget where the thread is he talked about it.
Can you say poofkaboom? I will let him give all the details so I don't screw it up heh
I think he used up his entire stamp collection shipping me the cylinder.
PostPosted: Sat Jun 07, 2008 5:03 pm
Some as found pics of the cylinder, plenty of aluminum stuck to the cylinder, muriatic acid will removed this.
PostPosted: Sat Jun 07, 2008 5:04 pm
The tabs on the exhaust manifold are about worn out.
PostPosted: Sat Jun 07, 2008 5:13 pm
Reed cage
PostPosted: Sat Jun 07, 2008 5:15 pm
Some nasty flow inhibitors ...
PostPosted: Sat Jun 07, 2008 5:16 pm
Now the intake exhaust and studs are remove its time to remove the aluminum smeared on the cylinder walls
PostPosted: Sat Jun 07, 2008 5:18 pm
Once the aluminum was removed I took a new stock piston to check the clearance the quick and dirty way, that's a .005 feeler gauge this cylinder will need bored to the first over bore.
PostPosted: Sat Jun 07, 2008 6:17 pm
LOL. the new lady at the post office does'nt know how to use the postage machine. Do you think i can weld some material to the ex flange to build it back up? I went ahead and sent the reeds just so you can take a look at them.
They looked fine last year when i took a peek inside.
PostPosted: Sun Jun 29, 2008 6:23 pm
Update, I remove the studs, exhaust manifold, reeds and intake, lapped the top of the cylinder so its flat again, bored and honed to fit new piston, beveled the ports, I cleaned up a few of the real nasty casting flaws too, their was a huge one in the exhaust port.
File comment: Exhaust manifold didnt match at all.
PostPosted: Sun Jun 29, 2008 6:27 pm
I touched up the exhaust manifold pretty much the same as done here http://pilotodyssey.com/manifoldrepair.htm
I put some copper wire in the holes then welded it a little, file it down then bevel up the back side of the hole like factory.
PostPosted: Sun Jun 29, 2008 6:28 pm
Still gotta install the studs and go through the reed cage.
