It is currently Sun May 18, 2025 12:46 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Dec 10, 2008 7:30 pm
this guy said he can sleeve the cylinder and bore it ready to run for $240 does that sound fair?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
PostPosted: Wed Dec 10, 2008 10:19 pm
Does that include a piston? He can't properly bore a cylinder for an aftermarket piston without having a piston in hand. I have in the past paid $300 (8yrs ago) for the sleeve to be installed, bored, complete piston kit with top end gaskets. Sleeves are usually in the area of $100 plus the labor to install. The $240 doesn't seem terrible with todays labor rates.
PostPosted: Wed Dec 10, 2008 11:42 pm
LA SLEEVE did a jug for me-it was alittle more than the posted price you have but it came with piston, rings and wristpin.It was for a 350 and was like 320 shipped on a 80mm piston Wiseco.Mine had a broken skirt as well-Hoser has the jug mabye he can post them Hoser -is Hares LC jug from 350 motor-you did a CSI on it.
PostPosted: Thu Dec 11, 2008 6:27 am
Have you checked with LA sleeve?
Guy talks a good game.
Any negative comments on his sleeve work?
PostPosted: Thu Dec 11, 2008 9:27 am
The last one, and only one, I did was also a 350 jug with a busted sleeve. I had a local machine shop do it. Total was right around $300 and I had to buy the piston on top of that. I bought a 80MM weisco, first bore 350 piston Weisco makes. I didn't realize at that time that I could have used the first 3 Art/Honda piston bores 78.5,79, 79.5 MM, with an Ebay original bore Honda jug. Point is that you may be wasting a few bores by going directly to 80MM piston. Also, boring big alone on a 350 does not make big power..., intake, carb, exhaust, clutching, and porting does(2 strokes in general). You can pick 350 jugs up on ebay for around $50 generally. I have heard that some Honda rings are no longer manufactured or in stock, but am not sure of that. Sorry, starting to ramble on,
Gary
PostPosted: Thu Dec 11, 2008 3:54 pm
can i buy the smallest Honda piston and have it sleeved to that?
PostPosted: Thu Dec 11, 2008 4:32 pm
I would think that the sleeve size is set at the stock bore, I have never got one though.
PostPosted: Thu Dec 11, 2008 4:52 pm
once you sleeve it you still need to bore it to fit the piston, then hone it, so you need to have the piston in hand
PostPosted: Thu Dec 11, 2008 5:37 pm
Ok here is a question how much will I really save after shipping the Crank out to be repaired and shipping the cylinder out to be resleeved over just ordering all the parts new from Service Honda? what would all of you do?
New Crank from Service Honda 366.22
New Cylinder from Service Honda 313.17
PostPosted: Thu Dec 11, 2008 6:03 pm
If you buy new while they are still available, then you will have the worn out parts to repair later on if needed. How long will these new parts be around? You are not saving a ton of money by fixing what you have.
PostPosted: Thu Dec 11, 2008 7:38 pm
King KX is right
Crank is a judgement call, I rebuild mine when I can. say about $140. in parts and $30.-50. in labor, so $200. or there abouts, you should be able to find a local decent guy, PM me if you have trouble.
Cylinder, I would just buy new until there are no more.
PostPosted: Thu Dec 11, 2008 8:00 pm
here is the email correspondence from L.A. sleeve it will be 276.50 to resleeve minus shipping so you save 36.67 over new and have to wait 3 weeks.
Hello Jake,
Thank you for your interest in our products and inquiry. L.A. SLEEVE can sleeve your ’89 Pilot FL-400R cylinder.
Here is pricing for sleeving and parts normally replaced:
Labor $160.00 (includes preparing cylinder, installing sleeve, match standard porting, finish bore for piston)
Sleeve $116.50
Piston Kit $155.18 (includes rings, clips, wristpin)
Top-end Bearing $16.75
Top-end Gasket Kit $32.70
Plus Shipping Charges
On our web-site,www.lasleeve.com, you can download the “2-Stroke Cylinder Job Order Form” found in the “Downloads” section on the home page. Mark the appropriate places and send it with your bare cylinder and new piston via UPS, U.S. mail, or Fed-Ex; be sure to insure your cylinder. Turn around time is approximately 3 weeks from arrival of your cylinder.
L.A. SLEEVE accepts major credit cards as payment (card must be in your name). Please provide the details requested on the cylinder job order form.
We look forward to sleeving your cylinder, if you have further questions, please contact us again.
Sales
L.A. SLEEVE CO.
12051 Rivera Rd.
Santa Fe Springs, CA 90670 U.S.A.
Phone: 562-945-7578
FAX: 562-698-7019
PostPosted: Thu Dec 11, 2008 8:29 pm
I wasn't aware cranks and jugs were still available, good info to know.
PostPosted: Thu Dec 11, 2008 9:10 pm
Here is what I came up with.
L.A. Sleeve,------------------------------------Service Honda
Labor 160.00----------------
Sleeve 116.50---------------------------------Cylinder 313.17
Piston,rings,clips,pin 155.18----------------Piston,rings.clips,pin 125.33
Top end bearing 16.75----------------------Top end bearing 9.88
Top end gasket kit 32.70--------------------Complete gasket kit 46.29
Total 481.13----------------------------------- Total 494.67
PostPosted: Thu Dec 11, 2008 9:12 pm
One advantage of new crank is it will be nice and tight. Once "H" measures up the bearing surfaces that should help with that decesion on crank rebuild. One advantage of new cylinder is You or "H" get to port to Your or His liking instead of first matching up exhingting cylinder on resleave. Either way degreeing it in will need to be done for max effency. If your old cylinder is to your liking then sleave it, if not start fresh and new. Remebr the new Honda cylinder comes one size fits all. So using a stock honda piston also one size fits all. Both cylinder and piston will need to be matched up to you liking on tolerences, watch those end gaps. "H" can hone it to your liking on that. I know "H:" already disaembled I hope he got to get base line degree #'s if was not in to bad of shape. Spare motor (( Internal Combustion Engine ? )), old would be ok. For replacemnet motor (( Internal Combustion Engine ? )) new would be better. that's how I would look at it. Either way when "H" is done I bet it would be nicely done. Whats you choice on head and CC's that should be considered on cylinder choice incase it's been ported and had exhaust port raised. This will effect the CR of the motor (( Internal Combustion Engine ? )). I would have "H" clean up new sleave and bore so LA sleave don't try to match up alignment and change the porting. Just my two cents.
PostPosted: Thu Dec 11, 2008 9:35 pm
If you go new sleeve you want to go with new Honda piston not a wiseco, I assume you will have to buy the piston and send it with the cylinder? I would also tell them you want the piston to cylinder clearance at .0031 for the Honda piston.
PostPosted: Thu Dec 11, 2008 9:43 pm
Hoser-any pictures of that jug LASleeve did for me on HARES old water cooled jug by chance?Just to show what they can do perhaps?
PostPosted: Sat Dec 13, 2008 11:36 am
Good advise "H", bore to minium clearence then hone if necessary according to end gap and camp. Stock Honda piston highly recomended with fresh stock bore. I have a sleave if you would like pics and port #'s
PostPosted: Mon Jan 12, 2009 1:01 pm
"NO MORE HONDA CYLINDERS DISCONTINUED"
PostPosted: Mon Jan 12, 2009 1:05 pm
i thought only "A"s were discontinued, now you saying ALL are? damn
PostPosted: Mon Jan 12, 2009 1:21 pm
we tried every cylinder part# unless someone knows a different one?
PostPosted: Mon Jan 12, 2009 8:11 pm
You still order the piston? Will need to send a piston with the cylinder when you get it sleeved? I don't want to run wiseco!!!!
PostPosted: Tue Jan 13, 2009 12:08 am
Yes i ordered the Honda piston.
PostPosted: Tue Jan 13, 2009 8:32 pm
Did they have the Piston kit?I was under the impression I had purchased the last jug/piston kit from Service some time back-or that's at least what I was told by them at least------
PostPosted: Wed Jan 14, 2009 12:09 am
they said they had the piston kit.
